Question about SanDisk Memory Media
My memory stick is protected
I always copy my pictures from my 2Gb memory stick onto my computer but this time when i put my memory stick back into my camera it says protected and now it won´t even let me take pictures.what do i do?
  • 341 Answers
On the memory stick there should be a little white slide tab. You move it up or down can't remember which way to protect your pics or unprotect your pics. The tab is on the side of the memory (usually) Hope this helps
Posted on Jun 21, 2009
    Novelist:
  • 133 Answers
Just wanted to know if there is a slide switch anywhere on the memory card? .. See the image below where it says LOCK:
http://www.labamanta.lv/cache/product_images/big/20090205/sandisk_2gb_sd_card_1.jpg
Toggle the switch if there is any and that should help.
Regards,
Srinivas
I have a san disk 2gb memory card for my nokia phone, i took my memory card out for the first time as i wanted to put the pictures from it onto my computer, everything worked fine, however when i put my...
you can not format your card without loosing data on it. The solution is to copy all the data to your computer, format the card (in your computer, still) and then copy the data back.
Hope this helps,
Lucas
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
Hii sir pls help me mine kingstone data traveler 2gb is write protected so how shall i remove write protected?
Copy all the files onto your 'C:' drive.
Spend $9 to buy a new 2GB USB memory-stick.
Copy the files to the new memory-stick.
Take a sledge-hammer to the old memory-stick -- to prevent anybody else from reading your files.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My mem card will only let me move pictures from my cell TO my computer but not also FROM my computer to my cell like it used to before it says "Remove the write on protection or use another disk" i dont...
This should help fix the issue,
You will have to open MY Computer or COMPUTER from Start button. Make sure the SD Card is connected to PC.
1) In My Computer, right click on the drive letter of your SD card and
2) Eject it.
3) Then pull the card out and stick it back in.
4) Try to write to the card. If it works, Proceed with your copying.
5) If it DIDN'T work, repeat steps 1 through 4 ( 2-3 times )
If this does not work, there is alternate method.
The Memory card has a write protect slider on the side. Try putting tape around the card to make sure that the slider thing does not slip into write protect mode when inserting the card.
Sep 07, 2010 | SanDisk 2GB microSD Memory Card
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
How I remove the writw-protection to the memory card
Hi!
In order to remove write-protection from the memory stick, connect it to the device in which write-protection was implemented on it then use the feature of the device to remove write-protection off the memory stick.
Should you require any clarification, you may write back.
Give a try!!!!!
Sep 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do remove 'write protection' ? So you can copy and paste files onto it.
USUALLY HAS A VERY TINY SWITCH ON THE SIDE OF THE MEMORY CARD.
May 28, 2009 | PNY 2GB microSD Memory Card
USB Write Protection Hi, I am trying to copy/delet files from/to a USB stick. window says: " The disk cannot be written to because it is write protected. Please remove the write protection from volume USB...
Put the memory card into the SD adaptor and turn the white switch on the left of the card in the opposite direction.
See if that will work.
You may have to turn your phone off and back on again as well after reinserting the card back into the phone.
Nov 19, 2008 | SanDisk 2GB microSD Memory Card
Photo problem. sony cyber-shot 10.1 MP silver touch screen
I think I replied this post! Take out memory stick and connect camera with PC without memory stick. Go to pic folder and copy it. Simple :D
Jul 31, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Copying computer pix to memory stick
The resolution is probably incorrect for the camera LCD. try changing their size to a standard size like 640x480 with a resize program.
Jul 13, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Lost Pics
Memory card error is common problems in various sd cards and cf cards. I took a closer look at my little SD memory card. It has a sliding lock on it to protect data. Check to see if the card works when you slide that lock up or down. Read more about memory card:
http://www.uflysoft.com/data-recovery-mac/memory-card-error.html
May 14, 2008 | Sony Cybershot DSC-T200 Digital Camera
Electronics - Others Logo
172 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
