Question about American Standard RAVENNA WALL-HUNG SINK - 8" 0268888.021
I have a wall hung sink with a drain that leaks because I can't get the washer tight enough to the fixture. I've tried a couple of different sizes of washers, but no luck. I don't know what brand it is.
  • 1,305 Answers
There should be between the washer and the sink fixture a large rubber washer that you can compress to seal the joint. You can also get a small tub of "plumber's putty. Use a small amount of putty, roll in a ball and turn into a snake shape..wrap in a coil around the sink before you slide the washer up and squeeze the washer into it.
Be sure to check the small ball socket that controls the sink drain plug. Sometimes the retainer nut isn't snug and it can leak a little and it will appear that the main drain is leaking... Hope this sloves your issue.
k
Posted on Jun 21, 2009
Base of single handle kitchen faucet is loose where it sits on the counter
there should be 2 plastic nuts under the sink that hold the fixture tight to the sink. if they are tight allready try to install washers and see if that helps. right is tight. left is loose.
Jun 08, 2012 | Delta Faucet Plumbing
Blanco Supreme 533-U sink drain leaking at seal
The sink basket/strainer that fits into the large hole of the sink should have either a bead of silicone sealant applied to the sealing lip of the assembly or a ring of plumbers putty. Silicone will work very well if the mating flanges are clean and dry.
With the baket in place, the rubber seal goes between the large nut and the sink. A bead of silicon on this is optional on the sink side of that rubber seal. and the nut tightened down snug , forcing some of the silicone out fro beneath the mating flange and rubber seal. Tight enough so the basket is not free to move. Be it plastic or brass/metal, that order is the same, only a plastic nut is not tightened as tightly as a metal nut would be.
On the bottom of the drain basket assembly there is a nut, to retain a plastic or brass tail piece. The plastic tail piece will have a polyetheylene "flanged washer" for a seal to the bottom of the sink basket. If it is a brass tailpiece, a rubber seal and metal nut is used with "pipe dope"/thread sealing compound used on the threads of the metal nut. With the plastic nut, you can apply a few wraps of teflon tape to the threads of the drain basket, but is not required in most cases as the poly flanged washer will form the seal. The plastic nuts should not be tightened any more than hand tight.
beneath that, the rest of the drain assembly attaches. If plastic- no more than hand tight. if metal, only about 1/4 turn past hand tight. Metal nuts and parts should use rubber gaskets/seals and the plastic parts should only use the poly tapered/lip seals.
Jan 15, 2012 | Plumbing
Is plasterboard (with battens behind) strong enough to install a Roca Kalahari wall-hung sink against or do I have to reinforce it using tiles or a bracket?
Ok. Big answer. Where the sink is going to be mounted there needs to be inside the wall structural support mounted between the wall studs. This could be a 2X6 or 2X8 nailed from one wall stud to the next at the height the sink will be mounted. Then once you have repaired the sheet rock you can measure the distance the mounting holes in the back of your sink are and drill these holes smaller than the mounting bolts/screws for your sink. Screw the screw portion into the wall using the nuts on the bolt side and a wrench. Remove the nuts and the slide sink into place where the bolts/screws fit into the mounting holes in the sink back. Install washers and nuts and tighten to wall.
Sep 01, 2010 | Roca Pacific Semi-Recessed Basin - Black
My newly installed pop up Moen drain included with my new Moen Adler faucet model CAL84502, leaks past the rubber gasket that holds it up against the basin overflow drain. What can I do to stop this?
Sorry to hear you are having problems with your drain Dave. It might be as simple as tightening the nut another 1/8th of a turn. You've got to be careful here as the plastic parts for the drain can easily break if too much force is applied. Hand tighten only.
If tightening it up doesn't work then disassemble the pop up and look at the rubber washer. See if there are any signs on the washer that might tell you where it isn't sealing against the underside of the sink. Check the sink to ensure it is not cracked or chipped around the bottom of the drain. If everything looks fine then reassemble the drain and look again for leaks. It's possible something could have become trapped between the washer and sink allowing a capillary action to let water escape at this point. If the problem persists try using a little bit of plumbers putty with the washer as there could possible be a defect in the porcelin or steel of the sink drain allowing water to escape. Let me know if the problem persists and we'll have another go at it.
Aug 11, 2010 | Moen 103459 Drain Pop-UP Plug
Water leak
Sounds like a hose on the inside of the washer. Have you checked them? If all of them are tight and not leaking for sure. It might be the drain stopped up or a slow drain. The water is pumped out of the machine faster than just a drain, like on a sink does.
May 31, 2010 | KitchenAid KAWS700L Top Load Washer
I have bought a snap-n-loc sink drain for my
You have a nut, a rubber washer, and a paper washer...and of course the basket...
PLace a bead of clear silicone around the bottom rim of the basket about 1/4" to 3/8" thick...then place it in the sink hole... then slide the ruber washer up from the bottom, the paper washer next and then tighten down the nut to squeeze the basket in there tightly... let the silicone squeeze out and after it get hard, about 12 hours slice off the excess with a sharpe knife... this will give you and very good leak proof seal... don't hook up the drain for 12 hours either...
heatman101
Mar 31, 2010 | Plumbing
Bathroom drain pipe has no threads
I 'am having a hard time visualizing this problem ? is your drain line a PVC pipe or is it the old style brass that was once used?
Jul 26, 2009 | Plumbing
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
How To Connect Sinks Drain
No matter what type of sink you purchase, the drain and water-supply connections are generally installed in the same way. Hand-tighten a female adapter onto the drain stub-out at the wall. Slide slip nuts onto the drain arm and the sink's tailpiece. Fit a P-trap in place and tighten the slip nuts by hand. Connect flexible water-supply tubes onto the faucet's tailpieces, and route them to the shut-off valves. Tighten coupling nuts with an adjustable wrench. Remove the faucet aerator, turn on the water, check for leaks at the shutoff valves, and then turn on the faucet to check for leaks in the drain assembly. Replace the aerator.
Aug 27, 2008 | Blanco 510-879 Single Bowl Undermount...
American Standard RAVENNA WALL-HUNG SINK - 8" 0268888.021 Logo
82 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
