Question about Magellan Roadmate 1200 Car GPS Receiver
SUDDENLY STARTED TO GIVE A MESSAGE:"SD CARD HAS BEEN REMOVED" CAN NOT RESET THIS CONDITION. EEMS NOT TO SEE THE CARD. HAPPENED IN THE MIDDLE OF DRIVING, WAS GUIDING OK.
    President:
  • 1,111 Answers
Try the reset first, if that does nothing you can either try the update or send it in for repair
Posted on Jun 21, 2009
When plugging the gps roadmate 1200 i keep getting the unit is in usb mode. How do I get it back to regular gps usage.
Posted on Jul 02, 2011
Not able to access play store, sd card and, some settings on kyocera rise after factory reset
you must do a system update to latest software version in order to access play store
Nov 20, 2013 | Cell Phones
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
Ahoo.comhi my panasonic viera lcd tv model: TH- 42 U20S, was suddenly stopped working, because I inserted a memory card instead of SD card on it and suddenly the unit was shut down and the light started...
this appears to be a common problem from what i researched the only fix i have read about was removing the sd card. and unplug the tv for about an hour to reset it.
Mar 14, 2011 | Televison & Video
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
Apr 27, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Mp3 keeps crashing !
Push the little reset button with somethin thin like a paer clip. the reset button is up by the locking slider.
Apr 08, 2010 | iRiver H10 MP3 Player
Ds lite unable to locate sd card - using R4 & micro sd
What you will have to do is re format you sd card, their may be to much on the sd card if you are saving files on it, if you have a 4gb sd card only put about 3.6gb of games on it, that leaves plenty of room for your save files, i have had this happen to me when i first started using sd cards, all i did was re format the card, then put the games on again with the firmware,then duplicated all the games and the firmware for the card on my desktop, then if it happened again i can just transfer them over,
Nov 02, 2009 | Nintendo DSi Black Console
Menory card unreadable etc.
ok check the card slot for the memory card the pins are bent... for shore
Sep 03, 2008 | HP Photosmart R707 Digital Camera
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
How to unlock UMAX 512 MB SD card
Try safely ejecting the card, it actually has a small switch on it, which depending on where its pushed will lock or unlock..look closely.
Oct 20, 2007 | Generic Memory PCI USB and Firewire Combo...
Magellan Roadmate 1200 Car GPS Receiver Logo
439 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
