Question about HP Computers & Internet
Dvd burner plays dvd's and cd's fine, will burn cd's but will not burn dvd's
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Can you tell me what is imprinted on the front of the drive?
  • bkben32
    bkben32 Feb 06, 2012
    it is a dvd rw/r dvd+r compaq r4000
  • HP Master
  • 32,281 Answers
Unless you have one of the very latest laptops, your model laptop most likely has a DVD ROM combo drive - which allows you to play DVDs and CDs also burn CDs/
You need to give me the make and model number of your laptop for me to verify if your laptop is capable of burn DVDs.
Posted on Jun 21, 2009
My burner will not burn cd's anymore. It still plays cd's fine as well as play and burn dvd's fine. I see no errors in hardware setup. It is a nec dvd +- RW ND 6650A that came with my Dell Inspiron E1705.
The CD Burner / Player / DVD Burner are all different heads. If the Dell Inspiron E1705 is an older model it is most likely you have reached the end of it's usable life for the CD burner part. If it is new the CD burner is most likely defective and hopefully warrantied. Otherwise these CD/DVD units can be replaced relatively inexpensively (as compared to buying a new laptop).
Feb 01, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
Sony DRU510A, will burn CD fine, but not DVD, will play DVD
Same thing is happening to me. Does anyone know of a solution to this problem?
Feb 06, 2010 | Sony DRU 510A DVD±RW Burner
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
Will burn cd-r but kicks the disk out whe I put in a blank DVD-r
Sorry but your burner is a CD-RW/DVD-ROM
this means you can burn CDs and play DVD
you cannot Burn DVD with this device.
info link here
http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=7470
Please don't forget to rate me : )
Oct 01, 2009 | Toshiba SD R1312 CD-RW/DVD-ROM Burner
Dvd burning problem
i experience to your problem, this your burning a VOB is very fine but it your going to open at the same dvd burner you cannot see the files inside and also if you play that to your dvd-player,.. you know this type of burning speed is the matter, maybe you burn at maximum, keep burning your files at low speed for recognizing its buffer in good result..
Jun 19, 2009 | NEC ND-3500A DVD±RW Dual Layer Burner
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 13, 2009 | LG GSA-H55N DVD-RAM Burner
Try and find the latest drivers for your drive.
Hope this helps! :)
Nov 23, 2008 | LG GSA-H55N DVD-RAM Burner
Burned CD's won't play in auto CD player
I had the problem of burned CD's not playing in my car. I used a CD-R and burned it at "slow" burn rate. Now I don't have a problem with playing the cd's in my car player. Try it, it worked for me.
Nov 13, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
CD-RW/DVD-ROM BURNER
if you wish to burn cd's which is your burner then you need a software called nero burning rom or any other burning software that lets you burn data or audio cd's or vcd's to burn with if you wish to burn dvd's then you need a dvd burner combo drive which lets you burn dvds
Aug 11, 2007 | LG GCC-4241N CD-RW/DVD-ROM (Combo) Burner
Open Questions:
HP Probook 6560b BIOS doesn't recognize working WD SATA HDD. I have verified that it works in another computer and two other SATA HDD's work in my Probook. I have a WD Black 500GB SATA HDD (model #WD5000BPKX) that was the Kubuntu OS drive in my old HP Probook 6550b and works flawlessly when I test it in my husband's HP DV2000, but the BIOS on my current HP Probook 6560b does not recognize it. Running a HD test within the BIOS returns no drive installed, however booting from Ubuntu 16.04 and 18.04 Live USB sticks shows the HDD in the OS's file manager and partition manager, and another (Seagate) SATA HDD works flawlessly in this laptop. I have restored the BIOS to defaults and the version showing within the BIOS - F08 - is newer than the one shown for Linux on HP's driver site. Are you aware of any incompatibility with this particular model of HDD? I have VirtualBox but no Windows computer, if it is advised to update the BIOS to the current F67 revision shown for Windows computers on the HP support site. EDIT: Solved. I had no access to a Windows computer, but figured for whatever reason the BIOS in a computer that shipped with a 500GB SATA HDD wasn't recognizing a 500GB SATA HDD. So I installed the original Windows Vista Basic on the older 320GB HDD, downloaded the current HP BIOS update for that OS (on my husband's Ubuntu computer, since of course Windows didn't recognize all of my hardware), copied it to the 320GB HDD, and installed it without a hitch. The Probook 6560b is now running under a fresh install of Kubuntu 18.04 on the 500GB SATA HDD that wasn't recongnized prior to that update. Maybe not the simplest way to resolve it, but at least it's fixed. Hope this helps someone else with an older laptop not recognizing their SATA HDD. :)
Aug 18, 2018 | HP Computers & Internet
Computers & Internet Logo
147 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
