Question about Goodman CLJ36AR42 Air Conditioner
Goodman split a/c unit
I have a spit air system and the second floor unit is not working? i just had the A/C repairman less than 2 weeks ago service them?
    President:
  • 3,433 Answers
Call them back.
Posted on Jun 21, 2009
  • Ned C Cook
    Ned C Cook Jun 21, 2009
    Call them back.
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
I have a CPLE24-1 split system. heat not working
I dont know where you are located but anything bellow 45 degrees a heat pump does not put out much heat. As it gets colder the effeciency goes down. So if you have 24,000 at 60 degrees outside at 45 it is 15,000. Now first thing have the charge checked. If a unit is one pound low it can loose 20 %. Next see if your auxilary heat is working . You have at leat 8 KW backup heat.This comes on the second stage about 2 degrees or 2 to 4 minutes behing the Hat Pump. Ask service tech for free estimate or call and get season check. They will go thru your unit and check everything and let you know what wrong and also clean the system. Cost about 49.00 to 69.00. I own a business and we sell a maintanance contract for 105.00 and check and clean the system twice a year.Keep in touch Rus
Nov 25, 2009 | Goodman CPLE24-1 Air Conditioner
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
2 weeks ago one of my units stopped working properly. It got warm during the night even though I heard the unit running. I shut it off and called for repair service. They changed the thermostat and it...
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Sep 09, 2008 | Heating & Cooling
Goodman CLJ36AR42 Air Conditioner Logo
73 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
