Question about RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer
Fan not working
My paslode pin gun fan seemed to be slowing down so i cleaned it now the fan goes once then stops and the battery flashes red and it wont go again ??????????
  • christoff4 Jun 21, 2009
    yeah tryed it with a few batterys and same problem in the troubleshooting book it said try the battery terminals but they seem ok??
  • 1,305 Answers
If the battery is flashing red, the battery is not charged or on a minimal charge.
Have you attempted to recharge it and does it still give you this symptom?
K
Posted on Jun 21, 2009
  • KEN LaPOINT
    KEN LaPOINT Jun 21, 2009
    The owner's guide suggests an uncharged battery. Make sure that the battery charger contacts are clean, the battery contacts are clean and if you can get tot them, the contacts in the battery compartment...
    The red light is in regard to the battery....
    Do you have a volt meter you could check battery voltage too..
    K
Paslode
Make sure that you dry the top of the motor housing and connections.Make sure that the piston is up as far as it can go.
When you depress the nose against the work the motor should run and if you look at the flashing light on the side it will stay constantly on and momentarily flash when you pull the trigger. If it goes red then check the battery is charged otherwise there coiuld be a fault with the motor.
Is the inlet Valve facing the correct way with the bottom of the "V" facing down into the machine.
Check the date of the gas, make sure it is not out of date.
Is the gas cold? warm the cylinder up by putting it in your trouser pocket for 10 min. Paslode make winter gas for these cold days.
Jan 10, 2013 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse framing nailer , iv cleaned gun and oiled , the fan works etc . seems to only fire if i have fully charged battery ,once used for about five minutes it stops firing . only way to get it...
When it stops firing is the little light on the side of the handle green or red? If it is red then the battery is draining down too quickly. Either the fan switch has malfunctioned causing the fan to run all the time (I have seen this before) or you got either a faulty battery or charger.
Mar 05, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Gun will not work, battery charged as soon as you put it in the gun it goes red.
hi it could be your gun if it is flashing red&green this means theres a fault with the gun if it is just red try cleaning the battery treminals with a bit of sand paper some times they get a bit dirty and dont get enough contact with the gun hope this helps
Apr 10, 2011 | RTO PasLode 900420 Impulse Framing Nailer
IM350 when battery inserted flashes green then goes to red. Tried battery in other gun and works ok. Tried full charged battery (green in other gun) and led goes red in this one. Measured voltage at 6.74v....
Check the battery contacts in the gun...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My IM65 light flashes green then red, fan seems to be working and the gun does fire
heatman101
Aug 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
My paslode keeps flashing green red after it fires once. I have checked the wiring and all seems fine. The trigger and contact switch are both working but when it sparks once it cuts out
is the fan working? if you have the tool partially disassembled and it seems that you know what you are doing you can fire the tool in this position to check for the entire function. When was the last time cleaned? To fire and test motor connect the head assembly back up laying to side so fan can turn freely then push trigger fan should come on and run for a matter of seconds, next depresss the safety switch and then trigger to get gun to fire, look at spark for crisp action, fan should be on and again run for a few. If not then you have a problem with either fan or spark unit. You can go to Paslode.com and type in your model and they have a troubleshooting guide in the manual that might help.
Sep 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
IM250 Paslode straight brad nailer, fan wont shut off
My paselode was doing the same thing, and I followed all of the cleaning instructions, but the problem continued.
If it was left alone for a minute, it would fire again, so I removed the cover over the trigger assy, and checked the spark plug wire connection. The trigger came out, and during reassembly, I noticed that the electrical switch was hanging, and slowly pushing back out.
I cleaned and lightly spray/oiled the switch pin, and voila.........works like a charm.
Jul 26, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 1st fix gun .battery fully charged and placed into gun.the light flashes green and the gun will fire once after which the light flashes red and the gun will not fire.any ideas.i have tryed other...
I would look at the fuel cell on the bottom is a expiration date and they will not fire older fuel. Also do you remove the battery and it does the same thing? When you depress the safety on the work can you hear the fan motor? You say the tool is clean does it have enough lube to move all items freely. Just a couple thoughts, Also look at the spark plug wire for being broke or coming out of the spark unit. Let me know and we will go into this deeper.
Jun 30, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode framing nailer 1998 yr. model when engaged wont fire
you have spark and cleaned tool correct, but fan won't turn that freely, if so the fan motor is bad, it should come on when you pull the trigger or move the roller lever for the safety. The fan is about 80.00 Let me know if I missed something and how did you check the spark?
Jun 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
277 people viewed this question
Top RTO Tools & Hardware - Others Experts
yoopertech
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
