Question about RCA HD52W59 HDTV Projection Television
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
  • RCA Master
  • 8,617 Answers
Sounds like the flyback is arcing your model uses the 270125 flyback. you can get the repcement with free detailed instalation insructions at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/270125/cName/flybacks
Posted on Jun 21, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Oct 31, 2012 | Philips 50PL9126D/37B 50" DLP TV
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
I need help with my rca tv
probably bad color wheel. not an easy repair. some of the rca dlp required the light engine be
pulled out to replace color wheel.
Feb 24, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
Problem
Sounds like the color wheel or coolin fan both can cause this symptom. If it stops as soon as the set is turned off its probably the color wheel. If it continues for a minute after power is off its most likely the cooling fan.
Apr 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD52W59 HDTV Projection Television Logo
205 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
