Question about Dell XPS M1530 Notebook
Won't run Windows. Message Appears:"NTLDR is missing. Press any key to restart. Press any key to restart
    President:
  • 632 Answers
You must not have installed windows properly or installed it from a corrupt CD..only re-installation solves this problem..run bios set-up and choose CD-ROM drive as first boot device..insert cd then save and exit bios..follow instructions on screen..
Posted on Jun 21, 2009
    Sergeant:
  • 193 Answers
The most common problem for that error is that the drive isnt set to boot from cd so go into your bios and set to to boot from cd.
2 Suggested Answers
  • 8909 Answers
SOURCE: NTLDR is missing press any key to restart message
DELL Boot error.
  1. You have to go to the BIOS make sure the first, second and third boot device is set to cdrom. Put your startup disk in the CD drive.
    2. once you see a prompt that says press any key to contintue to boot to cd press the Enter Key Once
    3. When you have a prompt that says welcome to windows press R to Repair press F3 to quit and press Enter to create a fresh new copy of windows. we press R
    4. You will be given a dos prompt
    5. Type c:\> cd c:\windows\repair, <Press Enter>
    6. Type c:\windows\repair> del c:\windows\system32\SAM, <Press Enter>
    7. Type c:\windows\repair> copy sam c:\windows\system32\SAM, <Press Enter>
    8. Type Exit
    9. Restart the computer
Posted on Jan 03, 2011
When uploading windows 7 I get a message: Can't load windows at this time because of a hardware configuration problem or I get missing NTLDR how do i fix this?
First make sure there are no Disks in any of the drives CD , Floppy and Usb
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32
New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in the computer, unless you are attempting to boot from a diskette Test all power and data leads that attach to your hard drive including IDE,SATA if ita flat 40 pin ribbon type it will be the first to fail. The leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. b> b>
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
After system recovery using recovery discs of "PowerSpec" error message "NTLDR is compressed PressCtrl Alt Del to restart" appears .How to fix it
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. Hope this helps.
Jan 16, 2013 | Computers & Internet
Error message "NTLDR is compressed" how to fix it
Jan 16, 2013 | Micro Electronics PowerSpec 6236 PC...
I have an Acer Aspire 3630 and when I turn it on, it comes up with a message saying "NTLDR is missing Press any key to restart". Does anyone have any idea of how to fix this, I do not have any CDs etc
It has to do with your operating system. The NT loader file is missing that's why it won't boot. You can download NTLDR or the best way is to reformat you laptop.
Sep 15, 2012 | Computers & Internet
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
NTLDR is missing press any key to restart message appears but cannot get it to restart
DELL Boot error.
    8. Type Exit
Jan 03, 2011 | Dell Inspiron 1720 (dncwma1_1) Intel Core...
NTLDR is missing this is the message i get then it says press any key to restart when u do nothing happens
remove all the external devices plugged into your computer. and try to restart. if it does not work,
You need to have your Windows XP disk with you to resolve the problem. You just need to copy it directly from the Operating system CD. The NTLDR is responsible for loading Windows so if its is missing or damaged, there's no way you can load Windows back unless you copy it from the CD to your computer.
follow these steps:
1. insert the Windows XP disk in your computer
2.Restart your computer and press f12 to open up the boot menu
3. Select CD/DVDor ODD from the options and repeatedly tap the enter key until you see the "windows is loading files" message.
4. select the option to repair your computer (letter R)
(A command prompt will open)
5. Log into your Windows installation by pressing the "1" key and press enter.
6. You will then be prompted for your administrator password, enter that password. (leave it blank if you do not have a password)
7.type the following:
copy e:\i386\ntldr c:\ (press enter)
copy e:\i386\ntdetect.com c:\ (press enter)
(letter e corresponds to the drive letter of your CD/DVD drive, change it if you have a different letter assigned to that drive. for example: Your DVD drive is drive F, instead of typing "copy e:\i386\ntldr c:\",type "copy f:\i386\ntldr c:\")
8. after succesfully copying the files, type in exit or quit and reboot the computer and allow it to reboot normally.
Hope this helps
Jun 18, 2010 | Computers & Internet
IntelLoader is missing
I think your computer displays a message that ntldr is missing.
Use the following steps to replace these files. Insert the Windows XP bootable CD into the optical (CD or DVD) drive and restart the computer.
  1. When prompted to press any key to boot from the CD , press any key on the keyboard.
  2. Once in the Welcome to Setup screen, press the R key to repair Windows.
  3. Press the 1 key and then press Enter .
  4. Type the Administrator password at the prompt.
  5. Copy the NTLDR and NTDETECT.COM files to the root directory using the following steps:
    1. Type copy d:\i386\ntldr c:\ (assumes the optical (CD or DVD) drive is d) and then press the Enter key.
    2. Press the Y key at the Overwrite ntldr? prompt.
    3. Type d:\i386\ntdetect.com c:\ and then press the Enter key.
    4. Press the Y key at the Overwrite ntldr? prompt.
  6. Once both files have been successfully copied, remove the CD from the optical (CD or DVD) drive and type exit at the prompt and then press the Enter key. The computer will reboot.
Nov 24, 2008 | Microsoft Windows XP Professional With...
NTLDR missing
I can get into the Boot First Screen but can't seem to change anything within it... These screens seems to be selectively responsive to my key presses.... I can get the bios screen up, boot order screen up but not necessarily do anything within them... e.g. I can't restart the pc using ctrl alt del when the missing NTLDR message appears.... also I have put an XP disc in and it says to press any key to BOOT from CD .... I Do so but obviously it doesn't recognise it so it gives me the missing NTLDR message again! :(
May 24, 2008 | Microsoft Windows XP Professional With...
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
Dell XPS M1530 Notebook Logo
142 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
