Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
No water coming into dishwasher
I have check the water supply installed by a plumber and electrical supply installed by an electrician. The machine does not receive any water. There is a pink wire that has come loose but i cannot find where to plug it in. The machine is under warrenty, Thanks jim lutz 704-867-2628 e-mail
  • 2 more comments
  • PHPHINPH Dec 20, 2007
    Sounds like my problem - Hit start and it makes noise but no water. I have not looked for a loose wire yet - any luck?
  • Anonymous Aug 08, 2008
    My dishwasher's motor seems to be working and you can hear it going through the cycles however, no water comes through and we have checked all wires and plugs and there seems to be no problem...but the water!
  • nbrownpatter Aug 08, 2008
    I am having the exact same issue. The motor seems to be running and the dishwasher is runnint through all the cycles although no water is being generated....and all pumps/cords seem to be functioning fine.
  • Anonymous Nov 12, 2008
    So, does anyone have a SOLUTION? No water is coming into my dishwasher as of yesterday, and there is nothing in the way of the drain, that I can see.
My Frigidaire runs for 4 hours. It takes 4 hours to complete a cycle.model-FDB8345
Posted on Jun 25, 2008
How to lengthen the water supply hoses. There to short to reach sink.
Buy a flexible braided hose for mains pressure. They come in different lengths.
Fit one end to the water outlet tap and for the other end you will need a fitting you can attach the dishwasher hose to that any plumbing supply has. I don't think you can buy a flexible braided hose that will fit to your water supply tap on one end and then straight to the end of the dishwasher hose on the other. You will need the adapter between the 2 to hook the fittings up. Use plumbers tape on the fittings when installing them for a good water seal.
Or you can just get a plumber in who will fit everything up for you and will also probably use a flexible hose to plumb in the water supply.
Jan 04, 2016 | Dishwashers
I have Rheem eld 80 and have no hot water. Electrician checked if that was the problem but he said the bottem panel thermostat needs replaced and to call a plumber. Can most plumbers handle it. Is that...
Yes a local plumber should be able to do it. Finding the part however may be harder. There should be a plumbers supply company that handles commercial units nearby.
Nov 06, 2010 | Rheem ELD80 480V Commercial Electric Water...
We have an ariston LS 620A dishwasher. For the last year every few months the dishwasher seems to cause a short in our electrical box causing all the power to go out in our house. It is only when the...
The problem seems to be water seepage into the electrical contact.
If the heater has lost its insulation this problem could accur
( element to body )
Disconnect the heater and give a try without any load and soap. If it
performs OK , you have to check the heater by removing from the
machine. Mainly I suspect water seepage into the electrical system.
Aug 30, 2010 | Ariston Technologies Dishwashers
When I plug in my dishwasher it trips my test fuse and none of my plug sockets work. Do I need a plumber or electrician?
Electrician. You have a short in the dishwasher which is an electrical problem. Is it tripping GFI outlet. If so the GFI is probably weak or overloaded. Try regular outlet not on the GFI circuit and see what happens.
Mar 17, 2010 | Dishwashers
My plumber just installed a new water supply line for my dishwasher. Now the pump comes on but no water fills up in the machine. If I fill the bottom of the unit with water, it works just fine. Even though...
You don't know how many times I've heard and found the shutoff valve off or partly turned off. Water entering DW is from line pressure not pumping. Items to suspect (again) the water supply valve (would'nt be the first time a new valve is bad). The supply valve (3374621) at the Dw, the float safety switch (normally at front left side,)...remove lower rack, lift float housing up and down. You should hear a click both ways and the housing should be free. Is the Dw fill valve getting control signal from timer. Should be 120v for about 60 sec.
Mar 10, 2010 | Whirlpool 24 in. DU915QW Built-in...
My Indesit D63 dishwasher hums but doesn't fill with water
Most likely your intake solenoid.
Here is how you check.
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If you are not getting water into the unit but you have lights on and you hear clicking and the timer runs and things are trying to work then we know you have power and the timer is running.
No water coming to the unit.
Make sure nobody shut the supply line off. There should be a tap under the sink on the water supply line to the unit.
Turn the unit on an listen at the base for a click as the water supply solenoid (electric switch) opens. No click?
Check the solenoid. Remove the machine from under the counter. There will be screws holding it to the underside of the counter. You may have to lower the legs to get it out. They turn with a wrench to lower.
Under the unit where the water supply line comes in is a solenoid switch it opens to allow the water to enter the machine. Water comes in under household pressure (it is not pumped in by the unit). Chances are it is faulty. Replace it as it can't be serviced.
Still no luck?
The unit is guided by a timer. The timer tells the machine what to do and for how long. If it fails the unit will stop or jam in one cycle. If you have a physical switch the you turn to select the type of wash cycle check it. If you are all touch control then replace the whole board or machine.
To check the switch open the control panel above and use a voltage tester to see if you have current at each cycle point. Cleaning sometimes helps if not replace.
Hope this helps you. Please rate this tip for me.
Mar 09, 2010 | Indesit 24 in. D63 Free-standing...
I have just purchased a used 501HT model and had it installed by a plumber and electrician. It does not seem to work, when I close the door and push the start button. Can you help ? Also, there is a liquid...
If your dishwasher has not worked since the intial set-up. It could be any number of problems. I would check and make sure your machine's electrical is hooked up properly. A common mistake during set-up of high temperature machine is an electrician will hook it up to 120V when it should be hooked up to 208V. There is also a service switch located on the inside of the lower service panel, usually marked FILL/ OFF/ ON
This switch will need to be in the ON postion. Also the machine has a extended wash/deelime switch located under the door this will need to be turned off in order for the machine to begin a cycle.
You can use a powdered detergent. A liquid detergent is the best way to go. Liquid is the most economical when set-up and titrated properly, as opposed to manualy filling the machine with powder every load. Powdered detergent often leaves a chemical residue on your warewash.
Dec 21, 2009 | Moyer Diebel 24 in. 501HT Built-in...
Cant get installation manual
A dishwasher is a simple install. You don't need a manual. First make it fit under the counter or where you want it. Pull it back out.
There are three wires to connect to the house supply line. find those wires. You have to hook up to 110 volts at a wall outlet or tie it to a 110 volt junction supply box. If you can't do that then you need an electrician because that's what the intructions would say. Then you have to supply water. The instructions don't tell you how to be a plumber. You have to figger it out and find where to hook up the washer to your plumbing. There are water tap kits available for this at all hardware stores, but you will have to learn how to be the plumber or call one.
Apr 30, 2009 | Dishwashers
Just purchased a miele g1142sc dishwasher had a mate over who is a plumber and installed it. No water is coming into the dishwasher is there any safety seals on the water hose, put water into dishwasher...
Hi eaglesblue,
I'm Harvey the Master Plumber.
Your problem is: Just purchased a miele g1142sc dishwasher had a mate over who is a plumber and installed it. No water is coming into the dishwasher is there any safety seals on the water hose, put water into dishwasher pump is working fine.
Please take no offense but a plumber is not the same as an experieced appliance installer. Any way, your mate may have done just fine but the water line is clogged or he failed to flush the line before hooking it up and you may now have a clogged solanoid valve. Did you run the d/w a couple of times before he left? Did you confirm it working then and now it's not?
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Miele Dishwashers
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
948 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
