Question about Logitech Cordless Mouse
Stopped working. battery changed, reset button
Stopped working. battery changed, reset button hit, rebooted. what next
  • barb400 Jun 21, 2009
    thanks for replyingl actually what finally worked was taking out the battery, blowing shaking it, blowing inside, replacing the battery.
    Novelist:
  • 133 Answers
Dear Barb400,
You might have tried this already however just wanted to make sure ... Did you try connecting the mouse to receiver .. I mean .. there is a connect button beneath the mouse and there is a connect button on the Receiver that's connected to the USB of your computer .. Did you try pressing connect button on receiver and mouse simultaneously for 2 to 3 seconds and release .. If not then please let me know if this works..
Even if it doesn't work still I would love to hear from you so that I can suggest some other troubleshooting steps.
Hope that works for you :)
Regards,
Srinivas
Posted on Jun 21, 2009
Locked
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 23, 2014 | Apple Air Computers & Internet
Kensington mouse reset after changing batteries?
reboot your system and see if it reconnects, if not remove your receiver reboot your system plug your reciever in on your desk top
it should say adding new hardware, or found on the buttom of you mouse it should be a pairing button press and hold down led should
flash and reconnect if not call the manufactor/
Nov 29, 2013 | Kensington Computers & Internet
Blackberry 8520 won't reboot goes half way then stops took battery out left all night still won't go any further what can I do ? Please
my phone does this ever so often... you will lose all the data on the phone. with the phone off take the sdd card out and then while holding the volume button (+ or - changes from phone to phone... hold the volume camera and power button and wait for the screen you dont ever see, if you stop holding or hold the wrong volume button it will not work... then when that screen pops up hit your menu button on the touch screen, use the volume button to scroll down to system restore or what ever its called and select it with the camera button... then reboot your phone.
Feb 08, 2013 | Cell Phones
Forward slash not working on my macbook air
Did you change the system font to one you downloaded from the Internet? Some of those are missing characters. If not,
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Dec 04, 2012 | Apple MacBook Air
Fan won't stop
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 27, 2012 | Apple MacBook Air Mac Notebook
Printer displaying E 2 2
Hi hatti
The E22 is the error is displayed in Canon printers. And it relates to waste ink pad full. follow the correct instructions for perfect results.
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
Take care.
Aug 23, 2011 | Office Equipment & Supplies
My 2007 paficia perferom service light keeps coming on and i already had a oil change it only has 60,000 miles and I was told it is not time for a tune up. why the light will not stop popping up?
Change the service interval on the menu button on the dash. Scoll through the menu till you get to the service miles hit the step button until you reach the next desired service miles. Then press the menu button once it will ask u reset service hit the step button twice this will reset the perform service light. Hope this helps please rate if it does.
Aug 31, 2009 | Chrysler Pacifica Cars & Trucks
Engine Life Warning Light Reset
disconnect the battery cable for 3 minutes
Jan 01, 2009 | 2000 Lincoln LS
''Page too complex'' message on HP color laserjet 2840 Multifunct.
On the printer, hit the menu button
Then navigate using your left arrow button until you see Main Menu - Service, then hit enter
then use the right arrow to navigate to high speed usb and hit enter.
it should now show on, use the right arrow once to change it to off and hit enter 2 times
let the printer reboot and its should be fixed
Nov 15, 2008 | Office Equipment & Supplies
Logitech Cordless Mouse Logo
541 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
