Question about Pioneer DEH-P8600MP CD Player
Pioneer DEH-8950BT Face stuck open, wont power up
I have a similar problem to yours. I went to remove the face off my unit yesterday and it ejected the CD which I poked back in. The cd loaded correctly but the motorized face didnt slide back up into place and now the unit wont power up. I have tried unplugging it and leaving it and also checked power and earth to the connecting plug.
Any suggestions would be most appreciated.
3 Suggested Answers
  • 3 Answers
SOURCE: Pioneer deh-p8600 Motorized face not functioning
You can assist the face in going all the way down, once it is in this position it will automatically eject the cd. When the face starts to come down simply help it/gently force it to go the entire way with your hand, mine has the same issue and this is what I do everytime and it seems to work fine.
Posted on May 13, 2009
kenw392
  • 2226 Answers
it probably has a bad flexible cable.
Posted on Jul 29, 2009
My radio is not responding.
Put the right bottom corner of the face to head unit,bring the left bottom corner to headunit and press gently.
Apr 08, 2009 | Pioneer DEH-P6800MP CD Player
Twice my Pioneed DEH-P7900BT has just stopped working. Keyboard went dark and the unit shut off. I pressed the button to open the face place and it opened and is stuck that way. It also didn't eject my CD...
This sounds like a wiring problem. Double check all of you connections. If the Connections look good then I would check the connections inside the radio. Check the power wire mostly. The wire could have a bad solder joint inside the radio itself.
Mar 02, 2009 | Pioneer DEH-P7900BT CD Player
Pioneer Premier DHH-P930 cd stuck, how to eject?
The eject button is on the lower right hand corner. The button should say open. It opens the face plate
Jan 31, 2009 | Pioneer DEH-P930 CD Player
Disc stuck in deh-p7000r plays but wont eject
should be a small pin hole next to the disk tray, 2 or 3mm wide. Insert a pin and that should then cause the disk to be ejected.
Aug 25, 2017 | Pioneer DEH-P7000r
Cannot eject or turn off power on my pioneer deh-p8600mp
when you take the unit out of your car and looking at the top of the unit there are two black screws. Remove those then remove the entire cd player cage by the 4 CHROME screws on the four corners of the cage the two in the front are in the two holes in the ver front (**use magnetic screw driver for this**) then disconect the two wire plug and the ribbon cable from the bottom of the cd player cage **BE GENTLE** there are two black tabs on either side of the ribbon cable. THEY ONLY MOVE ABOUT 1/8TH ON AN INCH using a jewler flat blade screw driver gently slide the clip out to un crimp the ribbon cable then once the cage is removed you can open the face. To open the face there is a white gear wheel on the rightn hand side of the unit you can rotate it with your thumb with a little effort. Rotate accordingly..... at that point you shouldnt have any problem but let my know if you do..
Dec 10, 2008 | Pioneer DEH-P8600MP CD Player
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
DEH-P690UB Wont Eject or Open
Push the button on the top right corner. It is a little black button that pops out. This should allow for you to bring down the face plate and you can then insert a cd. Hope this helps, also can you please rate my answer. Thanks
Oct 01, 2007 | Pioneer DEH-P690UB CD Player
Unit powers down when motorized face opens
i also have had this unit for over four years. the exact same thing just happened to me yesterday. i was thinking maybe it is the motor that opens the face. has anyone found an exact solution for this problem yet?
Apr 11, 2007 | Pioneer DEH-P8500MP CD Player
Pioneer DEH-P8600MP CD Player Logo
406 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
