Computers & Internet Logo
A
Anonymous Posted on Apr 28, 2014
My emachine wont turn on - E-Machines Computers & Internet
Miami PC Wiz Inc
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 41 Answers
  • Posted on Jan 06, 2015
Miami PC Wiz Inc
Contributor
Level 1:
Cheetah:
Answers
41
Questions
0
Helped
3016
Points
57
Need more details, but this might help. If the case is where you press the power button, and nothing happens the possibilities are is a bad power supply.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/yordan_0946180d068c57d5
Emachines tower turns on but doesnt boot up
When you turn it on, what happens, give as much detail as you can.
3helpful
My emachine EL1352G-41W wont turn on?
Power supply is most likely your problem--many desktops with this issue have before it happens an issue where it has to be turned on several times and will finally come on and stay on.
The power supply in most cases is a unit that can be removed and tested (most shops charge little or nothing for this.)
If you are able to get it out look for bad filter caps on that board--some examples:
If puffy caps are found you have two choices---replace them all or if possible buy a generic power supply replacement............
Emachine turns on but wont turn off or turn on monitor
check plug for monitor power and also cable from pc back end to ensure they are fully inserted
let me know
Emachines e625 wont turn on, light is on for adapter, still wont work
Your battery is not being charge you will need a new adapter it is not supplying a charge for the battery or the battery is not holding a charge. There may be a compatible charger for small fee located on Ebay for your model . 2. Contact the manufacturer for a replacement. There will be a charge.
Here is their support site address:
http://support.emachines.com/em/driver/nb/e625.html
3. they will require to know what you unit has that is ram, hard drive, video card, model no.
Emachine....uhh...wont turn on.. green light on motherboard. help
well this would be more simple for me since i have more than one pc so first thing i would do is try another power supply if that wont turn it on then i would say mobo, the PSU's of the emachines are **** and dont last too long...
well i would try the PSU first since its cheaper.
good luck
Emachine
There may be many causes.
First, if you get any Beeps, recommend you to remove and reinsert the Memory(RAM) sticks.
Do try booting after removing the CMOS Battery(The one like a coin on the motherboard). Check the manual for instructions to remove the CMOS Battery.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
