I have a quite old la pavoni p3v2 110v 2000w two group machine that I have just finished a rebuild on. The machine goes to full temp on the boiler, the steam is great, but I can't get more than about 140 deg out of the portafilters. I ran a few shots to make sure I was getting hot fresh water and nothing changed. I also am not getting hardly any water out of the left portafilter. The hot water tap is fully functioning at temp (180 ish). I am assuming this is because it is a heat exchange boiler and the steam and hot water tap come directly out of the boiler while the group head gets its water from the exchange. Any ideas where to start?
Check the top of the group head there is a large bolt, within that is the metering jet and filter, that might be the cause of the blockage(either the jet is clogged or the filter is clogged). As for the full temp on the boiler what reading do you get on the gauge boiler side, it needs to be at about 1.2 bars.
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been...
(More)
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been having near perfect coffee. Today for some reason, the shot has poured way too quickly resulting in weak coffee. The grind appears to be fine, I have tampered it the same as I have over the past week, the only thing that seems to be happening is the water coming out too quickly. Can you see a solution to this promblem? thankyou.
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process,...
(More)
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process, (very little came out) but now it is leaking from the right hand side when facing machine (but only when turned on) from the gap between the base and the body. I suspect it is the 3 way solenoid valve, but would like some advice before we attempt a repair. Is this a symptom of solenoid breakdown and is it a self repair job for a handyman husband?
