Air conditioner is freezing/icing up inside
We have a goldstar 10000BTU window air conditioner. It works great most days...But if it is left on for long periods of time the inside ices up, and it won't blow cold air anymore....Why is it icing up??
    Sergeant:
  • 340 Answers
Needs to be taken apart and clenaned
Posted on Jun 21, 2009
    Problem Solver:
  • 5 Answers
Dirty coils (i'm sure you already cleaned the filter ). The coils over time (Behind the filter) get some dust and dirt trapped in between the fins and restrict air flow causing icing for the coils. Do not wipe the fins as they will bend over restricting air floe and you may ruin the unit. You should clean the coil with degreaser (Detergent type) and you usually have to take it out of the window and take it out of the metal cabinet to wash the coils.
Posted on Aug 07, 2010
My goldstar 6000 btu window ac is dripping into the house
Sounds like you're using it when the outside temp is cooler than the inside temp. when this happens, frost will build up on the condensor. Turn the unit off until the ice melts off with a shim under the unit tilting it back towards the outside of the window to drain. If it continues to drip after melting all the ice off and letting it dry out, you have a small leak in the condensor, (unit must be old or worn out) that the freon pressure has leaked out causing it to condensate more. A good checklist would be to check the level of the unit, make sure the coils are clean and not bent, the age of the unit and for small areas of corrosion or white marks on the condensor before replacing it.
Aug 28, 2011 | Goldstar KG6000R Window Air Conditioner
Air condition won't cool
mcdevito75 here YES IT DOES, I'm no expert but that ice is the problem, remove the cover and filter and let the ice melt, DO NOT REMOVE THE ICE YOURSELF, YOU CAN HURT THE UNIT, let the ice melt, then doulble chech the unit is not set to low in temperature about 60 degrees is plenty or mid way thru the blue sign on the dial, also clean the filter.
Jun 23, 2010 | Goldstar KG6000R Window Air Conditioner
Low cooling out put can it be recarged myself
turn it off for a day ans see what hapens if it did not work it might be a clog in the system
Aug 05, 2009 | LG Goldstar GWHD5000 wall/window Air...
Have 5000BTU Goldstar window unit. Water dripping
the bottom of the case from the outside usually has a "divot" in it below the coil to allow flow from the hose that runs across the bottom of the unit, try pressuring up and "blowing out" any obstruction, if this does not work then you may have to disassemble the unit and verify the drainpan is not cracked below the indoor coil (rare)
Jul 13, 2009 | Goldstar WG5000 Air Conditioner
AC not blowing Cold Air
take ac cage off or ac out of window so insides are exposed take out side and use water hose and clean out side coils and in side coils dont bend these coils or u will be sorry,,,clean out good if not stoped up have freon put in
Jul 03, 2009 | Goldstar M5200R Air Conditioner
Dry mode
it is supposed to dehumidify the air by running the compressor for a short period of time but not long enough to lower the temperature to any large degree
Aug 05, 2008 | Goldstar KG6000R Window Air Conditioner
Buttons
F1, F2, and F3 are the strength of the fan blowing the air conditioner. F1 circulates the least amount of air, F3 the most. I generally find that if the air conditioner isn't getting the job done on F1, F2 will do it. I typically only use F3 if I just want to circulate air fast in my place for awhile. As far as what is "better" with closed vent or open, that depends on what you want to do. If you are using air conditioning on a hot day, then vent closed is better because it will cool only air circulating in your place. Vent open will allow fresh air in from outside, and if it's a really hot day, the air conditioner might have a harder time cooling off the fresh air than the circulating air inside your place (as it's continually being cooled repeatedly by your air conditioner).
Jun 10, 2008 | Goldstar M1003R Air Conditioner
Air conditioner
If the air flow is restricted or partially blocked (dirty cooling fins, filter etc), ice will form inside becaue the air stays in ithe cooling coil or fils for a long period of time. Lack of freon will not cause Ice formation because there is not enough cooling power.
May 24, 2007 | Goldstar R1003 Air Conditioner
Ice chunks
freeon problem or dirty filter
Heating & Cooling Logo
746 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
