Question about Dell Inspiron Computers & Internet
How to replace screen dell inspiron 3521
Can i replace just lcd or do i have to replace the whole screen unit?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Posted on Sep 29, 2014
SOURCE:
kbdesign
  • 370 Answers
SOURCE: need to replace lcd screen
Sure you can, and it is pretty simple. First off, you want to remove the bezel that is between the F keys and the monitor hinges. There may be a little screw on the back side of each hinge cover, and also under the battery if the battery is below the hinges. Once you pry the bezel off, you can remove the little screws that are under the round covers on the glass side of the monitor. There should be 4 or 6 of them located on the monitor bezel. Once you remove these, you can separate the bezel on the glass side from the back of the monitor. There may be 2 or 4 screws that hold the LCD to the hinges that will have to be removed. Now you will be ready to unplug the monitor from both the motherboard and the inverter. Replace the new LCD in the reverse order.
New LCD's can be purchased from Ebay at a reasonable cost.
Posted on Mar 16, 2009
  • 16 Answers
SOURCE: Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Posted on Apr 20, 2009
  • 36 Answers
SOURCE: my screen on my dell inspiron 1525 goes dim after
you can try adjusting the screen brightness manually by pressing the blue FN key plus the up/down arrow keys. brighter is FN+UP ARROW. if you have a program called quickset open that and there should be an option under power options/settings. if neither of those solutions fixes the problem then the problem is the screen. a geek squad (1-800-geek-squad) will repair or replace the screen for you. thank you for using fixya!
Posted on May 04, 2009
  • 7 Answers
SOURCE: Replacing LCD Screen
it depends on if the exisiting invertor is fine or not. If the panel is being replaced because it was cracked etc, then the chances are the invertor is fine and will not need replacing. Obviously if you don't get the same replacement panel that Dell originally used, then you may have to buy a different invertor & figure out the wiring connections to attach it to the motherboard.
Posted on Aug 17, 2009
Geekman
  • 32281 Answers
SOURCE: Need help for my Dell Inspiron 9400 Laptop
Try and determine what is wrong with your LCD screen first and you can then decide the best course of action. Follow these instructions to determine the fault and then check out LCD Parts WEB site for parts, replacement LCDs, service and DIY info..
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 03, 2009
Cracked lcd hp g6 notebook screen
if you want to replace the screen i suggest to replace the whole unit.since its hard to find lcd screen only unless in the manufacturer.then i'm sure the price is like you buy new one.
Aug 29, 2012 | HP Nx7400 Notebook Pc 15.4-inch Wxga Tft...
I get only a white screen when I put in the DVD. It shows power to the unit. There is no other aactivity on the screen.
The portable LCD screen panel that attach to the potable DVD player is dead.This DVD player is not repairable except u must replaced the whole LCD screen attachment lcd screen panel itself.Not worth repairing,will cost the same as the cost of a new unit.
Feb 07, 2012 | Polaroid PDM-0824 Portable DVD Player
WhT can I do with a 42in vizio with pressure crack on inner screen
Only for spare electronic boards for parts for other tvs only now.Sorry this tv it is worthless as a whole tv now.This tv is not worth repairing,because by replacing the tv LCD screen panel will cost the same as a new tv.Because tv LCD screen panels are very limited in productions by the tvs corporations and it is 90% important to tv functions to the tv as a whole unit.
Jul 18, 2011 | Vizio 42 in. LCD TV
Can i repair a broken screen on a lcd tv?
LCD stands for Liquid Crystal Display. It is all one unit and when broken can not be repaired. The only way to fix it would be to purchase a replacement screen but that would probably cost more than replacing the whole TV. You might look for a used TV of the same model with a good screen and a bad circuit board and exchange parts but it is far easier to replace circuit boards than LCD screens so if you find a similiar model with a bad circuit board take the good board from your set to make the one with the good screen work again.
Sep 08, 2010 | Samsung LN-S4095D 40 in. LCD HDTV
My bf steped on his laptop and there are 3 cracks that are black and green, can plasma screens befixed on the inside?
Laptop screens are LCD (liquid Crystal Display, most laptop screen are made up of 5-7 layers with the LCD plate in the back all bound together in an aluminum frame with the backlight installed on the bottom to light the LCD up. Thses can be disassembled and the inner plate replaced, but it is cheaper to just replace the whole unit.
Oct 13, 2009 | Computers & Internet
Cracked lcd tv screen
it's over with when you crack the lcd screen, the lcd assembly costs more than the whole tv. cheaper to replace this unit.
Sep 08, 2009 | Televison & Video
Broken screen
More than it costs to replace the whole unit. New units around 200
Jul 08, 2009 | Naxa Electronics NX-550 13 in. LCD TV
Possible fixing a broken sharp lcd tv?
It is possible to fix but unfortunately the whole lcd panel is one unit so if it is on the inside or outside the whole thing will have to be replaced. The cost on such a thing is right around 3/4 of the price of the tv.
Sep 15, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
THE SCREEN IS CRACKED
You can replace the screen yourself. If it is a regular Sidekick 3(not a limited edition) the a replacement will run between 40 and 50 dollars on ebay. It's only 2 screws to replace the whole flip unit.
Here is a guide so you can see how easy it is.
replacement of the Sidekick 3 LCD flip screen.
Check the lcd screens out here.
Sidekick 3 LCD screens
Apr 11, 2008 | T-Mobile SidekickĀ® 3 Cellular Phone
Sk2 screen broken
A replacement one costs about 30-35 dollars on ebay. That is fot thw whole swivel unit and lcd. You have to remove 2 screws and put the new unit in. It's quick and easy!
Sidekick 2 LCD screens
Feb 17, 2008 | T-Mobile Sidekick II
Computers & Internet Logo
59 people viewed this question
Clive
Clive
Alun Cox
