My WBXR1060TAWW GE washer is eating thru belts....I replaced one about 2 weeks ago and the new one is fraying badly. It looks like it's rubbing metal when going through the spin cycle... It all started with a spin cycle that didn't want to pick up speed on its own. I could get it started by spinning the tub from the inside and it would start going on its own. Then the belt broke. I replaced it and the new belt did the same thing within a couple of weeks. What is going on?
    Sergeant:
    Champion:
  • 362 Answers
Tensioner pully could have bad bearing when ran gets hot and tries to lock up causing premature belt wear. spin all pullys with belt ff any hard to turn or so loose they might fall apart
Posted on Jun 21, 2009
I have a Maytag Neptune front load washer that the tub is rubbing and is loud.
Could be the bearings . But it could also be the springs that center and hold tub in place. They weaken over time and it is not uncommon for a tub to be scraping because one of the springs is shot. When you replace one, you replace all at same time and eat your wheaties because they are hard to replace.
Sep 08, 2015 | Maytag Neptune MAH5500B Front Load Washer
Squeeking noise are the barron going bad
Squeaking noises are NOT necessarily an indication of bearing failure - but could be an indication of a slipping belt or something else rubbing. The machine itself may be rubbing against a washer, wall, door jamb, or anything really.
Look around the machine. See if it is in contact - or close to ant of these things. When it is running - it could be bumping against something. If nothing is found - have a look inside the the dryer. Inspect the belt and clean the drum where the belt tracks. Repl;ace the belt it is ready to break, missing parts or de-laminating. If you find shiny metal filings - that indicates metal is rubbing somewhere and is likely to be the cause of the squeak.
Good luck.
Apr 14, 2011 | GE Dryers
The drum inside my ge wbvh6240fww washer is loose. I can move it around with my hands. During spin cycles it sounds like a tornado, and the room fills with smoke from where the drum rubs. The belt is fine,...
I am having the same problem.
Did you find a solution.
Our washer is just a little over 2 years old and I am trying to decide if I should just cut my losses and never buy a GE product ever again.
Oct 12, 2010 | GE WBVH6240F Front Load Washer
I have a GE washer model wksr2100t8ww. It works fine but made a rattling nose during agitation. I opened the front to discover what looks like a piece of weed whacker string stuck and wrapped around the...
1) You r right it is NOT good! 2)Need Color and size to andswer that question 3)See if ur belts are missing a piece 4)Don't replace the belt unless you have done 1-2 and 3. Oil is normal. Like u tought oil in the bottom of the washer is cause of that object.
Oct 26, 2009 | Washing Machines
My hotpoint has quit spinning, how do I evaluate and repair
If it will not agitate or spin, you will need to replace the belt. If it will agitate but not spin, you have a bad transmission. This has been a nightmare to Hot Point (GE). I did warranty repairs for GE for 8 years. During that time, GE had me condemn on average 6 washers a week due to bad transmissions. Reason being, it was cheaper for them to send the customer a new washer than it was for them to ship me a new transmission and pay me to replace it.
Sorry but take my advise when I say, when you replace your washer, don't but a GE or Hot point. They still have not bothered to fix their transmissions.
Oct 16, 2009 | Hotpoint VBSR3100D Top Load Washer
My GE front loading washer Model WCVH6260 does not start the rinse cycle spin. It has a motor sound and some water seems to be draining but the rinse cycle does not spin and the motor continues to make a...
This has happened to us also. Our machine is 27 months old. I just had a non-GE repairman out and he showed me the mutilated belt. I was wrapped around the pulley. He said that the pulley had to be out of wack in order for this to happen because the belt looked in great condition (besides being in 3 pieces). Then the metal wheel (don't know the official name) is now warped and had gouged 3 grooves into the cheap plastic outer tub. So badly that it went thru to where the water is. So NOW, I have a big piece of scrap metal in my basement. I need a new outer tub, pulley, belt and at least 2 hours of labor. So a bill of 4-500$. I think GE can take this hunk of metal! But of course, GE has to send out their service man to inspect it. So I have to pay another service fee. They need to scrap this model and possibly others. What a waste of a whole lot of money. NEVER again.
Oct 01, 2009 | GE WSXH208A Front Load Washer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
New belt
Basically, you need access and loop/connect around 2 pulleys using a long screw-driver to assist when looping your final pulley. The pulleys are metal; circular in shape; older models have 3 pulleys (water pump).
When looping your belt onto your final pulley, I typiclly use and wedge a long screw-driver in-between the pulley and belt, while simultaneously rotating the metal pulley to completely loop the belt on.
Jan 15, 2009 | GE Profile WPRE6100G Top Load Washer
Washer does not turn or spins
the pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Whirlpool ler4634jq0
Your rollers probably need replacement. Get a bonified FSP idler instead of a crappy made in asia knock off. Check your drum slide. Rib side down with the belt to the drum.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 15, 2008 | Whirlpool LER4634J Electric Dryer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
