Question about Standard (CRT) Televisions
Philips model # 27M800 7603 will not turn on
This is an older tv and at some point the power button was pushed inside the tv. Sometimes when we turned it on with the remote it would not stay on or we would have to turn it off and then on again. One day the power light no longer lit up and it would not power up at all. We have small kids....they may have stuck something in the power button opening (they love to mess around with the stuff they know they aren't supposed to) or it could just be old ....I would like to fix it if possible though. Thanks
Why does this form think I have no body?
  • 93 Answers
Re: Philips model # 27M800 7603 will not turn on
Your problem is so simple and I'm sure you can fix it by yourself.replace the defective switch,but if it will not work,then check the str ic,the fuse and the horizontal output transistor
Posted on Nov 03, 2007
0 characters
3 Points
Is there a main power switch to a lcd Philips TV
Yes. There is a main power switch at its front panel. Refer its user manual for details. If it cannot be turned ON by this switch, the main power supply regulator board inside the TV is faulty, and should be replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Dec 14, 2014 | Philips Standard (CRT) Televisions
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
Rca tv
your power button is in trouble so , change it with a new one.
Oct 01, 2008 | Standard (CRT) Televisions
Magnavox codes
Try holding down the the code search button until the LED lights.. Then push the TV button.. with the tv on Start pushing the power button at one second intervals until the tv turns off.. Then push the enter button. that should find the correct code.
Jul 18, 2008 | Philips Magnavox 27MS343S 27" TV
Philips tv demo
Try holding the volume up and channel down buttons on the set at the same time. Give me the model # if that doesn't work.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
On some models the reset is unplugging for a minute or two and plugging back up. Otherwise you have a blown fuse where the power goes in. If you decide to replace the fuse do no go over 5 amps. If the replacement fuse blows there is a short in the set and needs a repairman.
Jan 02, 2008 | Philips 19PR19 19" TV
Tv does not turn on
Replace C2455 47uf 25V
Nov 24, 2007 | Philips 27PT543S 27" TV
Older GE television sound trouble
The first thing to check is the push button assembly maybe the volume down button has been pushed in too hard/far and is always making contact,sometimes when we clean the face of the tube water drips down in thru the edge of the frame in the buttonts,corrosion sets in and creates a short,if you are familiar with tv service you can chech the buttons thru the inside to make sure they are not pushed in but if you are not famliar be safe and call for assistance froma servicer.
Oct 11, 2006 | GE 32GT740 32" TV
Standard (CRT) Televisions Logo
313 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
