Question about Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas
STARITE MAXETHERM 400 - THERMAL REGULATORS KEEP GOING BAD
We have had our pool heater 8 months now. We have a salt system - the thermal regulator has been replaced 3 times and now this 4th one has gone bad!
Pentair says it must be our pool, but our water is tested fine at Leslies and Olympic pool, they say the salt, chlorine, PH etc are all accurate.
We believe this heater must not like salt water, the pool guy even put a check valve in and that didnt help. Any known issues with this heater and salt water?
  • 139 Answers
Water never actually comes in contact with above mentioned part,so i dont believe your htr knows or cares whatv system you are using.since its number 4 i would suspect a main board problem.voltage readings would be helpful
Posted on Jun 21, 2009
R= 5 code what does this mean
It is a software code displayed on start up. Is the heater having an issue?
May 20, 2016 | Sta Rite Starite 333 Btu Propane Gas...
Sta Rite 333 Btu Natural Gas Heater Maxetherm Sr333na Leaks water and high copper in my water
It sounds like your water has either been running at a low pH level, or you have a salt system. Basically your heat exchanger coil has dissolved into your pool water.
The exchanger can be replaced although it is pricey. I would recommend replacing it with a cupronickel coil. This is far more resistant to the type of corrosion you have experienced. Just be sure to keep a closer eye on the pH also.
Feb 19, 2013 | Sta Rite 333 Btu Natural Gas Heater...
Sta rite maxetherm wont fire i have 240v in 24v
It sounds like you have started debugging this heater. In the manual located at http://www.poolcenter.com/images/MaxEThermOwnersManual.pdf on page 29, 30 and 31 there is a schematic that you may be able to follow to figure this out the rest of the way. If you get stuck I recommend you call the Sta Rite technicalsupport at 888-782-7483 and they might be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
Aug 22, 2011 | Sta Rite StaRite MaxETherm Heater 400000...
What is the error code 06 mean , every time i try to run the heater i get error code # 06 Please explain
It means you need to repeat the checks on fuel supply, thermal regulator, check for correct orifices, etc., per your owners manual. Check pages 42-43 for more information.
http://www.staritepool.com/pdfs/MaxETherm.pdf
John
May 06, 2011 | Sta Rite 333 Btu Natural Gas Heater...
Heater wont heat it says 106 all the time
The thermistor is bad...its job is to read the temperature of the water and transmit it back to the control board. Your replacement part number is 42001-0053S.
John
Apr 22, 2011 | Sta Rite StaRite 400000 BTU Heavy Duty...
Max-e-therm thermal regulator goes bad quickly
thats is related acid left on the pool corroded i service so many salt pool with this heater and not problems at all the awser was the PH WAS balance on the past or now but the problem wont stop there will be future damage to the heat exchanger. are you add tabs to the skimmer? what happend to the heater is because low PH. SORRY not easy solution but to balance the chems and replace any corroded part
Sep 01, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas Logo
285 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
