Question about Philips 60PP9352 60" Rear Projection Television
I messed with the converge setting in menu now picture is messed up
    Sergeant:
    Champion:
  • 362 Answers
Manual should have code to put back to factory specs with remote that will fix it
Posted on Jun 21, 2009
  • Philips Master
  • 3,459 Answers
Please give more details.
Audio but only black screen for video on WS65807
First, the set has a hard reset but it will NOT affect convergence which is stored in a separate area of the set.
Model indicated has 3 hidden menus---all accessed with the Original remote and a 4 digit code.
At your own risk:
This is a V17 chassis that was used in 8 models.
It has 3 hidden tech menus: With set on:
Option menu is 8270 enter---The Option menu reset will return all settings to factory and also will clear any glitches out of the way--it as stated can cause Convergence not to be affected.
Circuit adjust menu: (stay out as one wrong move and fatal things can happen is : 8257 enter.
Convergence adjust menu: (better than customer and SAVES adjustments made in to the DCU or digital convergence unit in the set.
I STRONGLY SUGGEST YOU TRY THE OPTION MENU FIRST, IF NEED DETAILED INSTRUCTIONS I CAN LOCATE THEM FOR STEP BY STEP OF THAT.
SEE IF IT CLEARS THE MAIN ISSUES UP FIRST---IF YOU TRIED TO ADJUST CONVERGENCE IT MAY NOW BE MESSED UP BUT UNLESS YOU GET THE SET BACK TO WORKING SOMEWHAT NORMAL NOTHING TO WORRY ABOUT.
keep in mind I do this here for free and have worked on hundreds of these Mitsubishi sets.
SD TECH------ASK BEFORE YOU LEAP!
Dec 02, 2012 | Mitsubishi WS-65807 65" Rear Projection...
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
My picture is messed up. Its kind of unclear with
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 04, 2010 | Hitachi 50GX30B 50". Rear Projection...
Hazy and messed up color
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 22, 2010 | Hitachi 50UX57B 50" Rear Projection...
I have a 52'' Magnavox Projection screen tv and the colors are messed up. The best way to describe it is that it looks like your looking at a 3D movie without the glasses. Can you tell me what's going on?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips Magnavox 51MP392H Rear Projection...
Picture off center on Toshiba 46" rear projection HDTV
On some models there is a picture position setting. One for horizontal and one for vertical. Don't mess with convergence, that probably won't help. Older models use knobs; new ones use the menu. Either way, you are looking for position adjustment.
Older sets, for each there should be size, hold, and position. Same for menus but it may have a picture that looks like one square offset on top of another.
Good luck. and if you need more help, please state the model #
Ken
Jan 01, 2009 | Toshiba 42H81 42" Rear Projection...
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Bad Picture
When you say messed up do you mean the convergence is out? please explain a little more detail as to what you are seeing. Also when its messed up if you press the menu button on the remote does the menu look good?
Tim
Sep 10, 2008 | Toshiba 50H81 50" Rear Projection...
Picture WAY messed up!!
Go to menu, and under video or picture, go to advance setting and then go to convergence. This TV should be equipped with and automatic convergence adjustment. Just follow the instruction on you owners manual. If this does not fix it, it means that your convergence chips are shot, and you will need to have a train repairman fix it.
Sep 09, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Auto convergence
this point to the special fuse fl231 a small rectangular fusable link. .4 amps if you can get this fuse and you can solder repairs is not to difficult.. you have to resolder connections that cause this fuse to blow
Jun 20, 2008 | RCA HD52W58 52" TV
Philips 60PP9352 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
