Question about Samsung AW0603B Air Conditioner
Water spilled from window air conditioner while moving it
I wanted to move my window airconditioner to another window. It had previousley been in use in the old window, but once I pulled it out of the window, a bunch of what a presume to be water spilled all over the place. Is this normal? I didn't see a plug on the bottom, and the conditioner is only a year old.
  • 77 Answers
It is only condinsation, no need to be worried, it most likely works like your refridgerator, the condinsation gathers in a pan, then evaperation takes care of the water naturally. Nothing out of the ordinary.
Posted on Jun 21, 2009
Water got into the plug. Unscrewed, drained as much as I could and set down on paper towels for a few days. Plugged back in & worked. Moved the cord while plugged in & the ac blew out and will...
Hello, most likly you will have to replace the whole cord assembly, here is a link to parts for you AC http://www.appliancefactoryparts.com/airconditioners/goldstar/m1003r.html
Jun 08, 2011 | Goldstar M1003R Air Conditioner
My air conditiner does not want to turn on.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
May 31, 2011 | LG Goldstar GWHD5000 wall/window Air...
When the airconditioner is on cool.Water comes from the airconditioner inside and dripping on the floor.
If it's a car air conditioner, your condensate drain line is clogged. If it's a home window unit, it needs to be tilted outward more. The downward tilt should be no less than 1/4" per foot. If your unit is 18" from the window to the back of the unit, the back should be 3/8" lower that at the window....minimum.
May 14, 2011 | Mitsubishi Heating & Cooling
Where is the drain plug on this unit goldstar 6500 airconditione
There is no drain plug,if it is not draining,then the drain holes are stopped up with trash and debris,remove the unit from the window,and take it out side,use a water hose to clean it out,and you will be fine,if this was at all helpful,please rate,thank you.
Jul 05, 2010 | Goldstar KG6000R Window Air Conditioner
My roof airconditioner leaks drain water on the floor.
make sure the drain is not plugged and that condensation can get under the cooling coil to the drain pan otherwise it may be condensation forming on the grill, make sure the filters and coil are clean and you are moving lots of air.
Jun 02, 2010 | Coleman Mach 15 Air Conditioner
Why does my airconditioner leak
If this is a window ac then you need the back of the ac lower than the front, so the water can drain to the back.
Aug 18, 2009 | GE AZ28E15DAB Thru-Wall/Window Air...
Fujita V-Lec Air con
i need a window kit for my air con
Jul 04, 2009 | Heating & Cooling
Haier window airconditioner cooling is not effective
there is a temperature sensor bulb in front of the evaporator. check if it is too near to the coil. move iit away about an inch.
Apr 30, 2009 | Haier HWR12XCB Air conditioner
Emptying Water
open the big front door, pull the top of the water container toward you, take it out turn it over, unscrew the top, pour out the water
Jul 23, 2008 | DeLonghi Pinguino PAC-210 Air Conditioner
Samsung AW0603B Air Conditioner Logo
130 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
