Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
GE Nautilus won't drain after Rinse Cycle
Howdy! We have a 4 year old GE Nautilus dishwasher that's been a blessing...never had a problem until about 2 weeks ago. The machine washes fine, drains fine during the wash cycle, rinses fine...then AFTER the last rinse cycle ONLY, the drain pump will not fully engage and drain the tub before the heated dry comes on. The last rinse cycle starts normally - then, just when it's supposed to drain out the last cycle of water of the tub...the pump comes on for a second, stops, starts again for a second, stops and then the rinse cycle finishes and the heated dry comes on. The problem is...the tub is left FULL of water. It does not do this during any other part of the wash cycle. It drains fully and refills fine otherwise. If I fiddle with the knob and get it JUST RIGHT in the Rinse zone...then the drain during the rinse cycle will complete normally...but the next time the machine is run it will return to bad behavior and not do a complete drain after the final rinse.
HELP!
  • 5 more comments
  • Anonymous Nov 11, 2007
    This is my second GE unit in my second house and the same problem exists for both. Inevitably, at the end of the wash, there's a puddle of water that I have to manually scoop out. I did try to tweak the rinse cycle with the knob to get it to drain, but it only gets worst. I checked the drain line and there's no clog.
  • Anonymous Nov 18, 2007
    Yep, same problem.
    I have the same problem with my GE "Profile Performance, Quiet Power III" Model GSD5610D00WW. I suspect, but not yet confirmed it is related to the Timer. Check this link for more details on dishwasher timers and their functionality (and how to troubleshoot them). http://www.partselect.com/dishwasher+tes...
  • nc 1st time Apr 30, 2008
    YES ! ITS BOT DRAINING except out the door!
  • Anonymous Aug 17, 2008
    Exact same problem! 4 year old dishwasher and I must fidget with the knob to make the last cycle drain. Has anyone found a way to resolve this?
  • rjsmroberts Dec 09, 2008
    I have the same problem. I have a GE Porfile. It does not drain after the last cycle. I must restart a new cycle and then press the start button again so it will finally drain out the standing water. At that point, the dishwasher is finished
  • debbie8463 Mar 15, 2009
    I have the same problem. I'm looking for a solution. :(
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
2 year old GE Nautilus dishwasher
Check the pump, make sure it is working properly and pumping water out. If it is then check the drain hose and make sure it is not plugged.
Feb 11, 2009 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus dishwasher
Check inlet valves as if you have 2, it may fill using 2 inlets (hot & cold) but only rinse on using 1 ((cold only). So if the cold inlet is faulty, then you will only notice on the rinse. If thats not it then chances are it is the controller unit. regards
Jul 22, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
2,715 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
