Question about Dryers
Same problem I have an identical problem with the exact dryer. As it was out of warranty my husband pulled the back off and the part that makes the belt turn has completely deteriorated. there was a pile of black dust on the floor of the dryer. sound dodgy to me but anyway.
    Sergeant:
    Champion:
  • 266 Answers
R u refering to the pully if so buy a new one put bck on the motor shaft go back to where purchased and ask for part # its pretty simple
Posted on Jun 21, 2009
Takes about 4 hours to dry any load. Have tried different settings. Husband cleaned lint traps, hoses, etc. Gas turns on and shuts off about every couple of minutes. Any ideasa?
Most likely problem is the exhaust is plugged. Lint build up and eventually restricted the humid exhaust air.
To test for this locate the exhaust vent where it exits the house. With the dryer running feel for the air flow. It should be similar to the flow you feel from hair dryer.
Second test is to light load the dryer setting the heat to high and after several minutes of operation open the door and confirm the clothes are hot to the touch.
Hot clothes and no air flow for ever to dry!!
  1. Remove hose from wall connection. Confirm vent hose not plugged by running dryer. Very dusty process. If no air step 2.
  2. Remove vent hose from back of dryer. Confirm air flow from dryer. Very dusty process. No air step 3.
  3. Service dryer blower likely plugged with lint. If dryer basket turns I would assume blower is also turning connected by drive belt. The blockage internal to dryer.
  4. So if not 1,2 or 3 than blocked vent hose to the outside . Suggest using a vacuum hose to carefully try to retrieve lint build up. Lets hope that it is not a roof vent because it would really suck trying to pull the blockage out. And unless your Santa roof tops are dangerous places to play.
  5. Well at least at this point we know why the clothes are not getting dry. What ever you do do not breach the venting in the walls. Moisture will build up along with the lint and create havic with mold!!!
  6. Call your husband
26044146-iw0uppkrtuaby0cw3enjxd1j-2-5.jpg Not to sure about the leaf blower, Might work?
Dryer Vent Cleaning Quick Easy Trick
Jan 08, 2016 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer is a week old. ran a cycle and dryer turned off. didn't trip breaker. wouldnt turn back on. so turned breaker off for a while then turned it back on. now dryer powers on but for only like 10 seconds...
A week old dryer should have, in its warranty, a condition that you can get them to exchange this for an identical (hopefully working) model free. Do it now, that is a short time window. It's usually one month.
Nov 16, 2013 | Samsung DV50F9A8EVP 27" Electric Dryer...
What kind of plastic is the "window" in a frigidaire front loading washer made of? Recently when my husband pulled on the semi circular plastic piece, which is part of the "window", it split, almost c
Hello Ann Calk -Unfortunately depending on which part it is exactly since there is any adhesive available to glue it back together you need to purchase the entire door panel. I would suggest contacting a professional to accurately diagnose and repair the window washer.
Sep 30, 2012 | Frigidaire FTF2140FS Front Load Washer /...
I have a stackable washer and dryer. Both have worked fine except recently clothes started getting caught between the drum and the front frame of the dryer. My husband pulled it apart checked the screws...
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Jun 22, 2010 | Kenmore 63942 Dryer
Dryer is not heating my husband pulled the heatin...
It could be the high limit switch. It is about 1 in dia. And 1/4in tall. And it is hooked up in line with the heating element. There is two of them that can cause it. Take an ohm meter and check to see if power will run through it. 0 ohms.
May 21, 2010 | Dryers
I want to install the gearbox for audi a4 1.8 1996 model,
i assuming that you are replacing it with a new one if so then you nedd to make sure that it is exactly identical to the old one if it is the old you that you are trying to put back in place make sure that it is in the exact posistion that it was in when you pulled it off.
May 21, 2010 | 1996 Audi A4
Maytag Neptune Dryer is taking over an hour to dry a load
Check the exhaust vent out back of dryer to see if exhaust pipe going outside is crimped or blocked. Let me know if air flow is better if pipe is pulled off back of dryer. Thanks, Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Door diaphragm
grasp hook on spring pull wire out of the groove in the boot remove boot retainer pull boot over lip to release
Feb 01, 2008 | Maytag Neptune MAH9700 Front Load Washer
Doesnt Tumble
sounds like the belt came of track... pull front off dryer and check .. take 2 screws out where lint filter goes in.... take putty knife and there is 2 clips one on each side of top of dryer a few inches in on either side push in on clips while gentily pulling up on top ...one screw on each side of front .. take lid swithch wires loose pull up on sides of front and should come off
here how the belt should be on with idle pully
Oct 28, 2007 | Whirlpool LER8648P Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
Marvin
Marvin
