Question about Water Heaters
My pilot goes out when i turn the knob from the pilot setting to low temp
    President:
  • 3,433 Answers
Let the thermocoupler get hot enough. the bulb that sits at the tip of the pilot flame.. If after given adequate time to heat up, and it still shuts the gas off,, the thermocoupler is defective. From pilot to on, not to low.. good luck.
Posted on Jun 21, 2009
My reliance 502 gas water heater . The pilot is lite but no hot water coming out of tap?
After lighting the pilot, you must turn the gas valve knob from 'pilot' to 'on' at whatever temp setting you prefer.
Feb 22, 2018 | Reliance Water Heaters
Where is the pilot lite to the hot water heater
There is a small (usually ) aluminum slide door. You need to air out the immediately area of any possible gas, then turn the knob on the regulater to pilot, hold the button down for a minute or so then use a long match to light the pilot light inside that little door. Hold lit matches up to the little tube until it lights. Then turn knob to temp.
Apr 06, 2016 | Water Water Heaters
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Flashing ch on greenstar 42cdi boiler
ch calling for heat check ignitor or heating element
Oct 18, 2017 | Water Heaters
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 21V40-38 Gas - pilot light is on but when i turn knob to hot it does not do anything
Is the pilot knob turned to the "On" position? If the knob and temp dial are set in the correct position, you may have a recalled wtr htr which requires a retrofit "reset" button that needs to be installed. Call the manufacturer;s phone # that's printed on the side of the water heater and give them the model # and serial # and find out.
Douglas
Aug 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
The pilot on My atwood water heater will not stay lit after I release the knob. I have replaced the thermocouple and have a nice blue flame.
Did you make sure the connection between the thermocouple and the control is tight and that the tip of the thermocouple is in the flame?
Jun 28, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
No Hot Water in morning
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
Apr 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
