Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
My JBL Eon15 g2 has a cracklin sound within the main component when the bass is turned up. How can I fix this?
    Problem Solver:
  • 18 Answers
It can be the amp or the speaker itself. it has to be diagnosed by a service center.
if the amp is the problem, there can be board replacements or component level repair. if it is the 15" speaker, then it can be reconed with authentic genuine JBL parts returning it to brand new. cathy@speakerex.com
Posted on Jun 25, 2009
Remote reset
Yes the woofer and tweeter can be replaced but the woofer needs a recone kit to repair as the whole speaker cannot be replaced without replacing half of the speaker enclosure.... call JBL pro or a service center for help.
Oct 08, 2013 | JBL EON15 G2 Main / Stereo Speaker
Powered 15" JBL EON
There are two power supplies in there, one for the woofer and one for the tweeter.
You may have blown one of them.
Are you under warranty? If so definitely check the JBL website for a local authorized repair center ... they are local people, usually very nice and easy to deal with, and the warranty coverage is excellent.
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Dec 28, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Damaged JBL Eon15 Tweeter
you can probably by a generic type of motherboard from a shop like JAYCAR lookem up on the net ]
May 25, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Hiss from the tweeter nothing from the sub
Trash. Don't run your bass through speakers not designed for it. Likewise (from personal experience) don't allow microphone feedback to get into consumer speakers. Bye-bye tweeters in either case.
Nov 05, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon G2 Speaker
from our experience rebuilding woofers once the lead wires get pulled too much or start to strain you have been running too much power into the woofer and making the cone move too far in and out.You need to cut the input signal from your preamp down and cut the volume down on the speaker input on you eon. We keep seeing too many of these amped speakers blown from too much signal.
Oct 12, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON15-G2--Does the HF Amplifer to the driver have any voltage?
The 2 leads that come off the HF driver are different sizes...you should only be able to hook them up one way. Takes the guess work out of it for ya.
Assuming there is nothing wrong with the speaker, hooking up the 2418H HF driver to it should do the trick. However, I blew my HF driver a few months ago and bought a new one, only to blow it immediately. This was because the motherboard of the JBL EON G2 had actually failed and caused the HF driver to fail. Once I replaced the motherboard and the HF driver (again) everything was back to sounding great. Hope that helps.
Oct 10, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl eon g2 problem!
Could be any number of things, the amp may be damaged (do you use these things at high volume?) but if you are only getting bass it could be a fault on the crossover circuitry. Could be a loose wire inside but the build quality on JBL is pretty good so I doubt that.
How long ago did you buy them? If it was recent you may be able to take them back to the shop, otherwise I'd seek a professional repairman.
Btw, did you check the fuse?
Dec 02, 2007 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON 15 G2 clicks and pops
my son and i fixed an eon a decade ago that had this problem. we swept a sine wave through the audio spectrum and discovered it started barking somewhere around a low D on the piano.
Turns out the mains connection was intermittent right where it enters the eon from the wall. Soldered the ac power connections and the problem went away.
Nov 25, 2006 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
636 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
