Question about Fisher and Paykel GWL11 Top Load Washer
Leak/drip water into the drum even the washer is off.
GWL11 washer fill water even if the washer is off, Is the inlet valves bad? Do I need to replace hot and cold inlet valves, if so how and where is it located. Please advise a step by step procedure to locate the valves. Can you give me part numbers and where to buy it too. Thanks and God Bless.
GB
    Sergeant:
    Champion:
  • 266 Answers
Well i can only do so much from this end but the valves are locate in rear up on top they will b after the water spikets they shuld have a electronic soilenoid valve as well u neer a small 8inch pipe wrench should do and a screw driver its pretty self explanitary
Posted on Jun 21, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Washer does not fill with water but motor continues to turns drum
Yes the drum will always spin when filling it is called stirring, however, you will find you need to replace the (I assume) cold inlet valve, or you could put the cold hose on the hot valve and do a hot wash, this means it would fill with cold water, however some machines do have a sensor for sensing water temp, if this is so the machine will beep, and it may take some time to fill. :)
Dec 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
MAVT734EWW washer's water level not working, will just keep filling the drum and not stop even when open top door or click knob to off, have to turn water off at the source
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.Replace the water valve with this part.
Nov 30, 2010 | Maytag Washing Machines
When washer finishes cycle and spins out water will start dripping into the washer and will get the clothes wet if not taken out
You have a faulty water inlet valve which needs to be replaced. If it's cold water dripping into the machine then it's the cold water inlet valve.
Oct 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Internal leak on a kenmore top load washer
Yes, very likely is a bad water inlet valve allowing water to leak past it into the drum. Really not a difficult repair with a little help.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 13, 2009 | Kenmore 24032\24036 Top Load Washer
Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Apr 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Rinse Cycle Doesn't Fill with Water
You may want to double check you have the inlet hoses around the correct way as if you have the cold hose going to the hot valve it would cause this fault. If the machine doesnt spin properly also it could be a faulty Out of balance switch. cheers.
Apr 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
Maytag atlantas top loader water keeps dripping from top of drum
Your water inlet valve is probably leaking by. If the water pressure is too, or if there is sediment build inside the valve, sometimes the solenoids will not close properly. Try cleaning the valve to see if this helps. If not, I would recommend replacing it. Depending on which valve you have, repairclinic.com has two listed for this model washer for $20 to $30. Let me know if this helps, or if you need further assistance.
Apr 23, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
292 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
