Question about Maytag Neptune MAH5500B Front Load Washer
Washer maytag FAN6800AWW get Lr alarm and dont start, what is thi
Alarm Lr
  • 6,784 Answers
HI, this code is signaling an issue that concerns the actual electric motor. a service call is recommended if possible. either the MCU is bad or, the motor has completely failed.
Posted on Jun 21, 2009
After 2 day problems gone
Posted on Jun 24, 2009
What is the wiring and winding?
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak Maytag Neptune washer motor/motor control circuit board ...much this is very helpful, my machine is coming up with a "Lr"code which I believe .
Aug 20, 2015 | Maytag Neptune Washing Machines
It said Lr on screen and stops
LR = Locked Rotor on the motor. Many things can cause this. Please contact me, with more details willing to help all I can.
Apr 12, 2014 | Maytag Neptune MAH5500B Front Load Washer
My Maytag washer will not complete a cycle. The code Lr is display on the front of the washer. I have pulled the plug and reset the breaker.
Hi.
LR stands for locked rotor. The code is returned by the Motor Control Unit (an electronic module connected to the motor and to central control unit). The code is returned when no motion from motor rotor is detected. With many models LR may be due to a factory defect. Please call Maytag and check if any recall has been issued for error LR concerning your washer model. If recall has been issued you will get a kit comprising a new motor and wiring harness.
You can also try temporarily resetting the error by disconnecting power at circuit breaker (or unplugging power cord). If the error message is prompted again call Maytag.
Regards.
Ginko
Aug 08, 2011 | Maytag Washing Machines
The washer will not complete the wash cycle. Lr
http://www.servicematters.com/maytag_library/docs/TDL-0044B-B.pdf
If all else fails, replace motor control board, and/or motor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Dec 21, 2008 | Maytag Neptune Washer
Neptune Washer
lr is a code for a locked rotor assy, on the motor itself, depending on age of machine you might have warr on the motor(part anyway) check your user guide and warr info. probably gonna need to install a "neptune repair kit" which includes new motor and new motor controller
Nov 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune fronmt load washer Model MAH5500B
Lr means locked rotor basically you have serious problems i would call a service tech for this.
Sep 29, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Lr code
sometime resistor are a bit under valued and can burn up. Dont worry about your door lock. remember Lr stands for locked rotor.????? check the winding on your motor and never over look the pump. Have a visual inside the pump for blockage look for any shorts on your washing machine. I was told they have a ten year warranty on the motor. I always test all the conponents on a w/machine before I test it. lookup this site to see if your maytag is still under warranty???? maytag.com
Aug 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
176 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
