My hoover 750la only rotates one way something stops it going the other way
    Scholar:
  • 85 Answers
You should be able to take the agitator out of the tub. from where you load the machine. pull it out. there should be some plastic pieces that normally flip back and forth like a rachet mechanism on teeth made into the plactic main piece.
these small plastic parts most likely have just worn out on one side to cause it to just agitate in one direction it is hard to explain how it works. these small parts are likely to be located at the top of the agitator where you may not have to take the entire agitator out. the parts will be under a center piece on top.
hope this helps....let me know. thanks
Posted on Jun 21, 2009
Machine filling up with water but not starting hoover 750la
Did you try with temperature setting to the minimum?
Normally the machine needs to heat the water at programmed temperature before starts, it fails to do it because some issue on the heating system it would not start....
Nov 30, 2015 | Hoover Washing Machines
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
Aug 09, 2014 | Hoover Nano Cyclonic Compact Bagless...
Hoover 750la will spin but wont pump water out
lower the waste pipe into a bucket to drain as much water as you can out of the machine, gravity will pull the water out of the machine, continue until it is as empty as possible. Remove front filter which is on the bottom right hand side and check for obstructions.
Apr 10, 2014 | Washing Machines
I have a Hoover 750LA Top Load Washing Machine. It washes very well, but it doesn't seem to be spinning out. Clothes are still wet and a little soapy. How many belts does it have. Where is the pump on...
Try and choose a manual mode if there is one on the program controller. If this wont spins the motor it can be fault in the program controller unit.
You will need to check the voltage output from the controller during the spin cycle to confirm if there is a winding issue on the motor - if this is a high speed mode.
If so it is possible that the high speed winding is defective.
Jan 10, 2011 | Washing Machines
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not rotate on Hoover steam-vac upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
Generic problem for all Vacuums
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Hoover Vision 1600 drum not spinning?
Have the same problem, different model and it looks like I am outside 5 years spare parts. Probably just a belt or something from overloading. Also looks like it would nearly be cheaper to buy a new machine.You must have checked your pump???? What a rip off
Nov 27, 2006 | Hoover HF7 160E Front Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
