Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Kitchen aid oven door glass shattered
While cooking french fries the oven door glass popped and shattered. Nothing was touching the glass it just shattered all over the interior.
  • Anonymous Mar 27, 2014
    Cooking bacon
  • 4 Answers
Gget a new door
Posted on Jun 21, 2009
I have had this cooker since Nov 2013 while cooking sausages 01.02.15 the oven door shattered. I believe this is a design fault
Be careful with glass oven doors, common problem with shattering glass doors is hanging a wet/damp towel on the handle ( as this is the best place for them to dry!) When the oven is hot! . glass is not able to handle such a extreme change in tempetures. Hope this may have answered what could of happened
Feb 06, 2015 | Ovens
Replace inner glass on kitchen aid wall oven
This can be quite a difficult issue to deal with.. This is really a job for a pro technician, honestly. But if you should choose to try it. Remove the oven door from machine, by opening door slightly and looking at hinges you should be able to be able to slide a small arm on the hinge that locks the hinge and stops the door from closing. You then hold door and move toward closing it and lever the hinges out of their space and carefully place door on floor. Then you have to disassemble the door and remove glass. The video below IS NOT EXACT but will help you with what your up against.
Feb 02, 2015 | Ovens
Kitchen aid oven /range model # kgrt607hbl4
The "window" is comprised of two sheets of glass enclosed by a metal band. Heat expansion results in a less than perfect seal and admission of material thrown off by cooking. It is not practical to attempt cleaning it.
Jun 25, 2014 | KitchenAid Ovens
Electrolux EOG9330 Oven Door Glass shattered!!
It is quite common for this problem to occur.
There is no one satisfactory explanation for this to happen, but happen it does.
DO NOT use the oven until you have it repaired.
Contact the makers or one of their repair agents to get a new door glass fitted.
Hope this helps, and in the meantime have a nice xmas, go out and let someone else do the cooking for you..
Merry Xmas.
Dec 25, 2009 | Electrolux EOG9330 Gas Double Oven
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Door glass shattered 3 hours after cooking
The problem is with the glass. They apparently did not use a strong enough tempered glass during manaufacture. I would call the company and tell them what has happened. They should replace it. It must have been a design flaw or something else. They should make it good. They may want to make a recall.
Feb 25, 2009 | Ovens
KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
1,280 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
