Question about Comfort-Aire BHD-301 Dehumidifier
Dehumidifier runs for short time, then shuts off, no water collec
I have a comfort aire dehumidifier. Had it about 3 years and worked great with infrequent use. Went to use recently after cleaning carpets and it ran, then shut off and would occasionally turn back on but is not collecting any water. Cannot find comfort-aire support on web and lost manual. Please help!
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
22yooper
  • 828 Answers
SOURCE: Comfort-aire dehumidifier 501 cycles on and off
It is possible that the humidity is below the set point of the dehumidifier. They will run for a short time until they get a true fix on the actual humidity then shut down.
Posted on Jun 29, 2008
  • 225 Answers
SOURCE: kenmore dehumidifier runs but won't collect water
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. It may slide upwards out of the casing or downwards unto the bucket area. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry, in which case the compressor will probably not run.
A running compressor can usually be detected as a deep throbbing from the machine. If it is running, but not cooling the pipes behind the intake grille, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this may be the cause.
Explore along these lines and let me know what you find.
Cheers, D
Posted on Jul 31, 2008
MNTECH
  • 1543 Answers
SOURCE: not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Posted on Aug 28, 2008
Hi my comfort aire dehumidifier is brand new. It was working fine controlling the humidity and the reservoir was filing with water. All at once, it acts like it is contolling the humidity, but there is...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 10, 2011 | Comfort-Aire BHD-501 Dehumidifier
The machine runs for just a few minutes, but then shuts off before taking in any outside water.
heatman101
Feb 22, 2011 | Comfort-Aire BHD-301 Dehumidifier
Repair on Dehumidifier comfort-aire runs gets no water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Oct 07, 2010 | Comfort-Aire HD-651 Dehumidifier
My small inexpensive dehumidifier stopped working, its trying to start but just can't. I have never cleaned it, lost the instructions. 1 yr. old it worked great all this time . Thanks Johnny L. PS its...
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 17, 2010 | Eva-Dry EDV1100 Petite Mini-Dehumidifier...
When I start the dehumidifier it will run for a few seconds and than shut down. I have unplugged it and re-started and it does the same. Can you help me out
heatman101
0-0-0-0-0-0-0-0-0-0-0-0-0-0-0-
Sep 12, 2010 | Comfort-Aire BHD-301 Dehumidifier
It runs for a few seconds and then shuts off
heatman101
Aug 29, 2010 | Comfort-Aire HD-301 Dehumidifier
My dehumidifier model bhd-501 won't shut off& is very hot. What might be the problem? Thanks
heatman101
Jun 18, 2010 | Comfort-Aire BHD-501 Dehumidifier
My comfort-aire dehumidifier #BHD-301 just stopped working. Any suggestions? Should I be doing some kind of regular maintainence?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Sep 12, 2009 | Comfort-Aire BHD-301 Dehumidifier
No water collecting, unit running
the collector base under the tubes just collects water and drips it through a hole into the water bucket. there must be a loose hose(if it has one) or the base collector or bucket has a crack, as they usually are plastic. also if the unit is sitting on a very uneven floor this will happen
Jul 24, 2009 | Goldstar DH3010B Dehumidifier
Jun 28, 2008 | Comfort-Aire Dehumidifiers
Comfort-Aire BHD-301 Dehumidifier Logo
248 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
