Question about Dell Dimension 9100 PC Desktop
Continuous vertical white band display problem
HP Pavilion zd8000 laptop.
One-inch wide vertical white band from top of screen to in front of task bar, initially appears during Windows XP startup.
Also having trouble installing Windows service pack 3 (no idea whether or not problems are related).
Saw an advertisement to fix this problem by downloading a driver -- have not tried that yet, as I don't know if the download is trustworthy.
Steps I've taken so far that have failed:
- rebooted
- changed aspect ratio
- changed display settings
- left computer off for a few days to cool off
- checked for Microsoft updates/drivers
Thanks.
  • 157 Answers
What is the error from installing xp sp3?
Is the white band always there? it is either a problem with the lcd panel most likely, or the graphics card. try a different monitor if you have one.
Posted on Jun 21, 2009
I have a hp pavilion 17 inch laptop and the screen is starting to get white vertical lines. I have 2 lines now. How to I fix this problem? Mrs. O'rourke
you have to first diagnose if the issue is with the hardware or the software.
You can do that by checking if you are getting the lines in BIOS or at the HP logo. if yes you have to get the screen replaced
Else you can simply reinstall the drivers
Jul 05, 2010 | HP Pavilion zd8000 Notebook
I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
Mar 19, 2010 | HP Pavilion zd8000 Notebook
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
Vertical multicolored lines appear. Sometimes there are couple of vertical white stips and vertical lines
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mainboard. Have it checked by a professional.
Oct 05, 2009 | HP Pavilion zd8000 Notebook
White vertical line on monitor screen
The vertical line is because the screen is going, it needs to be replaced fix the problem. Try searching on Ebay if your laptop isn't under warranty.
Aug 30, 2009 | HP Pavilion zd8000 Notebook
Same problem with my zd8000 HP Pavilion laptop
what has happened with your notebook is a simple wear factor. on the LCD screen there are ribbon cables witch join the main PCB controller head to the LCD laminated portion (what you see) have begun to wear. i have just recently replaced a screen because of the same issue. try gently flexing the the screen and see if the lines dissappear. next open the screen up, and check the cable running to the back of the screen take care as to not damage anything.
Aug 12, 2009 | HP Pavilion zd8000 Notebook
I have laptop dell inspiron 9300 it 17 sreen , it has a white verticle white line about on the middle about inche 1 1/8 wide hohow to fix? thank you...very much
Unfortunately, there is no way to fix it.
This line called "Tab Separation" of LCD.
You'll need whole new LCD display.
Very very common problem.
Apr 29, 2009 | HP Pavilion zd8000 Notebook
Hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Nov 17, 2008 | HP Pavilion zd8000 Notebook
Display
It could be a bad screen, but I'd suggest checking the screen cable connector (unplug and reseat it a couple of times). Also, check for any breaks, wear or fraying on the screen cable.
Have a super day!
R-
Nov 05, 2007 | HP Pavilion zd8000 Notebook
Dell Dimension 9100 PC Desktop Logo
468 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
