Question about Samsung PCL5415RB 54" Rear Projection Television
Red and Green flashes
I have enjoyed my Samsung PCL5415R for about 6 years without any problems until bright red and green linear streaks started flashing on the screen. The tv image does not appear to be altered. Any help is really appreciated.
  • 1,694 Answers
Re: Red and Green flashes
Possible CRT coolant liquid leak onto circuit board.Check
for moisture evidence....................T.
Posted on Nov 03, 2007
0 characters
3 Points
My samsung projection PD 01 TV will not turn on. The green and red light just keep flashing what should I do
Green ad red light flashing may be a lamp. If your lamp is more than 2 years old it could be suspect to failure. When was the last time the lamp was changed?
Aug 30, 2015 | Samsung Projection Televisions
Samsung HL-S5679W won't start - LED light blinking
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
May 11, 2010 | Samsung HL-S5679W 56" HDTV
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Projection Televisions
Samsung model number PCL5415R The blue bulb is weak. where can i get one and can I replace it it is a 52inch projection HDTV ready
You may also have a problem with the convergence. There are three color cans that project the image on the screen. A red one, green one and a blue one. The blue one is the one that you should try and adjust. Have you tried to realign the convergence yet? You should be able to go into the menu setting and locate this option is is typically done using the remote. What you will see is some cross marks starting in the center and move to the four coners. When you adjust it you will want to align all three (red, green and blue) crosses where neither color is more prevalent. If you are unable to get the blue can to align with the others, there is a problem with the convergence board. These boards or ICs can be replaced, if you have a repairman fix it your looking at around $250 - $400. If you would like to fix it yourself you can get the parts from...
NOTE: "Most of the text above was gathered from another online source"
Aug 28, 2008 | Projection Televisions
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Kp-57hw40 screen goes bright red or green then powers off
heres a recall of sony hope it helps.
Dec 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
94 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
