I just found out that my Panasonic cordless phone has been on the line for at least the past day and everyone calling my house has been getting a busy signal. I unplugged everything, then replugged the lines, I got a dial tone. I hung up...then picked up the phone awhile later and was hearing the "please hang up..." message from my telephone provider before the screaming alert sounds. I tried the "OFF" button to hang up, then "TALK" again and it was still giving the alert sounds, the only way it stopped is if I unplugged the telephone cord. Have tried it over and over again and the same thing. The phone won't hang up...it's like it's going on 'HOLD' instead of 'OFF'. Had to go find a 20+ year old corded pulse dialing phone I still had in the basement, lol...please any idea what I can do to fix this issue?
We recommend you test the main base unit with a different telephone cord on a different telephone jack.
Testimonial: "I have done that, still the same thing. I have three handsets and all do the same thing. I have removed the battery also and tried my backup replacement new battery for the phone also and it's still doing the same thing. I have tried three separate telephone cords and also three different telephone jacks around the house. It seems it must be something wrong with the base unit of the phone, because the handsets seem to be fine, and doubt three different handsets would all have problems."
I have done that, still the same thing. I have two handsets and both do the same thing. I Have removed the battery also and tried my backup replacement new battery for the phone also and it's still doing the same thing,
I actually have three handsets (or is it headsets?) total, and it must be something wrong with the base unit. I have tried three separate telephone cords and also three different telephone jacks around the house. It seems it must be something wrong with the base unit of the phone, because the handsets seem to be fine, and doubt three different handsets would all have problems.
any other suggestion please?
SOURCE: Almost constantly gives "no link to base" message
I had this problem too. I popped the battery out, waited 1 minute then put it back in. Unfortunately this clears the memory of all recent calls, etc. but it immediately started working again. So far its only happened once...
SOURCE: Answering phone system cannot handle nuisance calls
i have problem with my phone (TX TCA115UA B)
i can not turn on the tone regime (now is on pulse regime when i dile the number)
SOURCE: no dial tone and "line in use " message
the wire that is used to connect the line to the telephone is not proper...
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
SOURCE: Unable to hang up phone. The line is busy/can't make/receive call
sounds like you need a DSL filter, go to page 41 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
