Question about Dell Studio 1737 Laptop
Unable to disable touch pad
Had the touchpad disabled before, then Windows did a driver update and now I cannot find the disable procedure again in control panel.
  • OnionCreek Jun 21, 2009
    The touch pad is not listed and has No check box to disable it. The Mouse has no check box either. The Keyboard is listed as a standard ps/2 keyboard and has no mention of a touchpad.
  • 39 Answers
Go to Control Panel --> Mouse
Under Device Settings there is a Disable button where you can disable the internal pointing device.
With Windows Vista and newer models there is also usually a Check box where you can Disable internal pointing device when an External USB pointing device is attached.
The check box is usually the better option if available.
Posted on Jun 21, 2009
How do I disable the touchpad on my hp probook 4530s?
03-27-2013 FINALLY A SOLUTION THAT WORKS TO DISABLE HP 4530S touch pad:
Clickity click on Control Panel/System/Device Manager/Mice/Synaptics PS2/Driver/Update Driver/Search Internet for latest driver.
It should find and update with driver dated 01/10/2013 which is driver version 16.3.9.0
HOORAY! Double click on the upper left hand corner of the mouse pad, the light comes On indicating that the mouse pad is OFF - and it works just like HP said it would two years ago. Knowing HP, who knows for how long it will work.
This works on Windows 7 - on other systems your milage may vary.
Dec 11, 2011 | HP 2133 Notebook PC
I want to disable the touchpad and use the external mouse exclusively
Some laptops don't have dedicated buttons but you can use Function keys (like Fn + F5 on Dell computers) to toggle the state of your touch pad. In the case of HP laptops, you can hold the top-left corner of the touchpad for few seconds and it will disable the touch pad - repeat this to re-activate it.
New laptop computers either have a physical on/off button to easily disable the touch pad or there's an icon in the system tray that lets you manage the various settings of the touchpad. If you don't have that icon, you can go to Control Panel -> Mouse Properties -> Touch Pad to enable or disable the touchpad.
The touch pad can also be disabled through the device manager. Type devmgmt.msc in the Windows Run box to start the device manager, expand "Mice and other Pointing devices", right-click and disable the driver entry that says Touch pad or likewise.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 30, 2011 | Toshiba Satellite P305DS8836 Notebook
First at all, I'm sorry about my terrible Eng. I have a HP 6720s laptop and there is a problem with touchpad. How can I disable the touchpad with 'fn' key? I looked every pages on my...
OK to disable you Touchpad you can press Fn + F12 or you can go to Control panel...Search for devices...or you can go to Device Manager. In the menu Look for sp/1 or sp/2 it will have your installed components or drive information for you mouse pad/touch pad. You can right click it and disable it. Also if you are having problems with you Touch Pad you can also download the driver and re-install in on your drive.
Go to this website: CLick Here For Hp Synaptics Drivers.
Click Your OS,
Search For Synaptics driver.
May 24, 2011 | Computers & Internet
I have a dv4000 (dv4272us) and when I'm typing, periodically i must be brushing the touchpad because the cursor moves someplace else and begins typing somewhere else on the document. I using windows 7 and...
You should be able to disable the touchpad from the CONTROL PANEL - MOUSE options.
Go to Control Panel, click Mouse, click the big pointer, click Device Select, look under Touch Pad, click the blank "dot" next to Disable, also checkmark the box next to Disable touchpad.
Click APPLY and OK, then Restart your computer if necessary.
Apr 16, 2011 | HP Pavilion dv4000 Notebook
Disable touchpad
hello... try to see if the touch pad application is correctly install,, to be sure use your application installer and try to reinstall your touchpad...
Mar 30, 2011 | Dell Inspiron 1300 Notebook
How do I disable the touch pad on my Latitude E5400? The curser jumps all over when I type. On my other laptops, there is a button clearly marked to disable the touch pad and this has solved the problem....
  1. Click Start.
    Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  2. Click the Dell Touchpad tab.
  3. If you are not getting the Dell Touchpad tab, update your driver, you will get the Tab.
  4. Click on the picture of the touchpad.
    Click Device Select.
    Click to check the box to the left of Disable Touchpad / Pointing Stick when external USB mouse is present.
    Click Apply, then click OK.
  5. Click the X in the upper-right corner to close the Dell Touchpad Utility.
Aug 31, 2010 | Dell Latitude E5400 Laptop
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Can't disable touch pad
Windows hides rarely used icons. If your does, then the task bar shows a left pointing arrow < . Click it and look for the icone for touchpad.
If you cant find that icon,
In WINDOWS XP
1. Start
2. Contol Panel
3. Right click the Mouse icon.
4. Under the Touchpad ON/OFF thumbnail, put a check mark in the disable option.
5. Use the same procedure to enable touchpad
Aug 22, 2009 | Dell F3534 Touchpad
Disabling touchpad
dmusick,
  • Goto Start -> Control Panel then double click on Mouse
  • There you will find the to make disable your touch pad.
  • Also there might be a key (button) near touch pad this key toggle your touch pad on/off.
Thanks
May 18, 2008 | Computers & Internet
Dell Studio 1737 Laptop Logo
1,091 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
