Question about Compaq iPAQ H3850 Pocket PC
How do u connect to the internet from a Compaq iPAQ H3850 through your PC?
My Compaq iPAQ H3850 Pocket PC doesnt have a modem or bluetooth ect. It has to rely on the PC to connect. Can I connect to the internet?
3 Suggested Answers
  • 3 Answers
SOURCE: how to connect to the internet
I am tried to set up the msn with my ipaq h3955 and i couldn't, but I went at in my ipaq and I selected messenger and I configured it and now I can chat wit it. I hope that this helps.
Posted on Feb 29, 2008
  • 555 Answers
SOURCE: lost instruction manual for iPAQ H3850 Pocket PC
You can download the User Guide, Reference Guide, and Supplemental Guide for the iPAQ h3850.
*If you find the solution helpful, please rate it!*
Posted on May 14, 2008
Posted on Oct 24, 2008
0 characters
1 Points
I can not figure out how to connect my device to the internet Wi-Fi, I want to go on internet explorer and it won't connect
To send and receive e-mail with Inbox and view Web sites with Pocket Internet Explorer, set up a remote connection using a modem card or an Ethernet/LAN card.
To connect to the Internet with a modem card, you need a phone line, a dial-up Internet Service Provider, and an optional Single-slot or Dual-slot PC Card Expansion Pack or CompactFlash (CF) Card Expansion Pack.
*Insert your modem card
*From the Start menu, tap Settings
*Tap the Connections tab->Connections Icon-->Internet Settings-->Modify-->New
*Enter a name for the connection, select the modem type, and select the correct baud rate for that modem.
I have shared the basic steps..which I refereed using the reference guide for the model that you have specified from this website.This you can easily get my typing "reference guide for Compaq iPAQ H3850 Pocket PC" in Google...and the first link lets you download the PDF..Follow the steps carefully and connect to the internet.To check for the internet speed you can use which gives you accurate speed results.
Oct 28, 2013 | Compaq iPAQ H3850 Pocket PC
To do a full reset, simultaneously press the two outer application buttons and the reset button on the bottom of the handheld for 10 seconds.
This should help!
Mar 15, 2011 | Compaq iPAQ H3850 Pocket PC
Im trying to access the internet through my ipaq 3800, can anyone hekp with this?
hi thanks for using fixya!
If you want to access the internet thru your ipaq, you should first contact your network service provider to send you the GPRS configuration and settings. From then, you may now enjoy the connectivity of your ipaq.
Apr 22, 2009 | Compaq iPAQ H3850 Pocket PC
Ipaq 3850
Here's an eBay auction for a the ipaq, cradle and cover, no bids yet.
There are also a number of chargers available. A Google search also returns several vendors for ipaqs and accessories.
Apr 02, 2009 | Compaq iPAQ H3850 Pocket PC
How to work it
Is not there a button in the upper right corner? If this is helpful please post as such. TY
Jan 18, 2009 | Compaq iPAQ H3850 Pocket PC
Compaq iPAQ H3800 Pocket PC
I had the same problem with my iPAQ H3800. I bought a replacement battery on eBay for £7.49 and now it's fine.
Dec 11, 2008 | Compaq iPAQ H3850 Pocket PC
Lost instruction manual for iPAQ H3850 Pocket PC
May 14, 2008 | Compaq iPAQ H3850 Pocket PC
Pocket pc 3850
Set it up with what? Do you mean sync with your computer? Are you using USB or Bluetooth?
Best thing to do.
1. Unplug your USB connection from PPC -> Computer
2. Uninstall Activesync if you have it installed
3. Restart your computer
4. Re-install activesync
5. Restart your PPC
6. When asked to connect the PPC connect it via USB
Jan 06, 2008 | Compaq iPAQ H3850 Pocket PC
BLANK Pocket PC ! - iPAQ 3885
Yes, I did. Actully for my model it is at the bottom. I used that along with RESET key - which makes 'Hard Reset' - but the same Red screen remains....
Sep 12, 2005 | Compaq iPAQ H3850 Pocket PC
Compaq iPAQ H3850 Pocket PC Logo
63 people viewed this question
Top Compaq PDAs Experts
Cosma Papouis
Cosma Papouis
Level 1 Expert
Are you a Compaq PDA Expert? Answer questions, earn points and help others
