Question about Nintendo DS Lite Console
Unable to get past warning message on DS lite. Seems to reboot.
Just bought a DS lite, battery is fully charged. Power on unit and see the health warning screen from there if I touch the screen I briefly see the menu screen, then warning screen comes back. It is like it is rebooting. Screen will go black, chimes sound, warning screen...
What can I do, it is a present for my daughter do I need to return it to the store? Help...
  • 39 Answers
If you just purchased the unit then most likely it is still under either the store's warranty or the manufacturer's warranty. I would return it right away and get a replacement. It should NOT be behaving this way brand new.
Posted on Jun 21, 2009
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
Nothing working on screen when fully charged
Make sure all games and accessories are removed. If you cannot get it to work, you will have to get the unit services because you need the ds reset.
there is also a possibility that the motherboard is damaged or the IOS for the unit.
If this unit was modded in anyway, the unit could be in a bricked mode. Bricked means useless and a paper weight.
gl
Jun 13, 2010 | Nintendo DS Lite Console
How long should my battery last? I bought an nintendo DS lite and I forgot to ask?
Hello there, the Nintendo DS Lite has four levels of brightness. The battery will last 15-19 hours on the lowest settings, and 5-8 hours on the brightest.This can also vary depending on the type of game activity."
So the DS should last the whole time in even on the highest brightness settings, if fully charged. Nintendo states that it takes 3 hours to fully charge the DS.
hope this helped, also this site will also help you to get your ds battery to last for longer
 http://www.ehow.com/how_2015000_extend-b…
good luck
Apr 21, 2010 | Nintendo DS Lite
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
DS lite will not read any DS games. When the DS
Thats normal, there should be a flashing part of writting at the bottem of the screen saying "touch the screen to continue" just touch the screen.
Dec 26, 2009 | Nintendo DS Lite - Onyx
Power shuts dowd
the battery is not charging correctly or has a fault contact nintendo
Aug 06, 2009 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Is it a costly repair job or buy a new one?
could be you need a new battery...wotrh a try. Always go for the cheapest option first.
Jan 07, 2008 | Nintendo DS Lite Console
Battery?
send it to nintendo
Oct 31, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
132 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
