Question about Canon imagePROGRAF W6200 InkJet Printer
I keep getting a printhead error....I have replaced the printhead with the canon spec printhead and I keep getting the same error message.....any thoughts?thanks,Parker
  • Anonymous May 06, 2008
    I had the same problem with my W6200. The solution is usually to replace the print head but you may have to enter the service menu to get rid of the error message before the new print head will work. If you haven't installed a new print head you may try to remove your old one and reinstall it but in my case I had to buy a new one at about $550 to get my printer to work again.Be careful when removing the old print head! when the ink line assembly is disconnected from the the head ink will drain from the bottom of the print head. Have a pan and some paper towels ready! To get rid of the error message turn the printer off.Hold down the paper source button & the online button and hit the power button one time. Keep the paper source & online button pressed in until the printers name" Canon W6200" is shown on the printers LCD screen then release the two button. The printer should intialize and enter service mode. At this point I unplugged the printer for about five seconds before plugging it back in. If you have already installed your new print head I would try hitting the power button now and see if your printer starts working. If you have not installed a new print head I would open the cover and remove the old head at this time. close all the print head latches & the front cover. Press the power but to turn the printer on.After Intializing the LCD panel should say to install Print Head.Open the front cover and install the new print head.You can try reinstalling the old one after cleaning all the draining ink away. It doesn't hurt to try the old one before shelling out $550 for a new one but in my case I had to install a new head.Close all the print head latches & the Front cover.The carriage should move to the right and begin to prime the lines and fill the head with ink again.This will take several minutes.Your printer should start to work after the new Print head is primed!
  • 27 Answers
Check the wiring assemble connecting the printhead to the printer and where the wiring connects to the printer. Anything loose here would prevent the unit from correctly reading the sensors on the printhead. Just a thought.
Posted on Jan 08, 2008
Are there air bubbles in the ink tube lines?
is your printhead draining ink onto the paper?
Most likely you need new ink tubes.
Posted on Apr 18, 2008
Error code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Mar 05, 2013 | Office Equipment & Supplies
Error code U052; keeps saying incorrect printhead installed - the printhead has never been changed
Per Canon's website, and this just worked for my mp620:
Turn the printer on.
Open the cover.
Remove the ink cartridges.
Remove the printhead.
Re-install the above (this resets the printhead).
Close the cover.
Printer should initialize and go to home menu screen.
Nov 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Error code uo52 how to reset
This indicates and error with the printhead. lull out the printhead and reseat it. If the message persists, you will need to replace the printhead. Normally, the error message automatically resets when you have inserted an undamaged printhead.
Let me know if you need additonal help or have questions. Thanks.
Sep 05, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Check Printer and Press resume key message along with Alarm light
Too many things can cause that, paper jams, carriage errors, printhead problems, purge assembly errors, feed roller errors, need more info to be of any help.
Aug 12, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Error message u052
That is a printhead error, sounds like you will need that new printhead.
Aug 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon ipf 8000 Error Code E161-403F
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
Canon Image Prograf w6400 error E02802
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Print head error message
reset it in window printing menu. perhaps it works.
Dec 03, 2008 | HP Business InkJet 2800 Printer
Print head problem
Dear palia1234,
Blinking in orange 5 times indicates that the printhead error occurs. You need to replace the printhead with a new one. But be careful before replacing the printhead, check your printhead if any smoke smell or indication of short circuitry present. Replacing the printhead in this case will harm new printhead. You'd better to take your printer to the nearest service center.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 08, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon imagePROGRAF W8200 InkJet Printer Problem Printhead Error! Turn Power Off!
you need to enter a service mode before the error message pops up. hold down paper source button + online.
that should override the message before it pops up.
go to replace print head selection. or do a clean. it may still be working. let me know if this doesn't work....but at least you can still get past the message now! marty
Oct 27, 2007 | Canon imagePROGRAF W8200 InkJet Printer
Canon imagePROGRAF W6200 InkJet Printer Logo
1,988 people viewed this question
old marine
old marine
