If it has wiring in place to power the lights and mounting locations, go buy some turn signal lights that will look good and fit the mounts you have. Connect the brighter colors from the bike wiring to the brighter colors of the turn signals and the same for darker colors.
If you buy signals with LED lighis, buy a 12 Volt turn signal flasher that is made for LED's--eBay has them. If you choose turn signals with incandescent bulbs (the traditional type), be sure each bulb draws 16 or 17 watts as other wattages will not allow a standard flasher to operate correctly--google the bulb number to find out. With other bulb wattages, the signals won't flash; they will stay on or not turn on at all as standard flashers are made to drive 2 16-watt bulbs; 32 watt loads. The good news is that the flashers made for LEDs will work with any type of bulbs or LED's, so go ahead and order one of the LED flashers to avoid trouble shooting the signals once they are installed.
SOURCE: 03 HD dyna wide glide blows oil from breather...
How many miles do you have? You probably need to have your oil pump alligned. They get out of wack and cause over oiling. I believe it caused by not being able to return oil efficiently. An evo tappet block alignment tool is now used to align the TC internal oil pump.
SOURCE: How can I remove the seat on a 2002 HD wide glide
Best as I can remember, you take a single bolt out of the back of the seat, lift the rear of the seat and pull to the rear.
Good Luck
Steve
Testimonial: "Thank you for the helpful information."
SOURCE: Turn signals on my 01' wide glide won't work? Fuse
Contact me directly and I'll send you some trouble shooting charts. They are out of an older book but the troubleshooting steps are the same. [email protected]
Steve
