Question about SanDisk Sansa MP3 Player
Hoh to fix a mp3 player that doesn't turn on
Won't turn on after 9 days
  • 728 Answers
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Posted on Aug 05, 2009
Frozen on o2 screen. wont turn on/off.
Hi Sam, The link below is a YouTube page full of videos showing how to turn on your mp3 player and unfreeze it.........CHEERS..
https://www.youtube.com/results?search_query=how+to+fix+a+mp3+player+that+won%27t+turn+on
how to fix mp3 player that won turn on YouTube
Apr 29, 2016 | Audio Players & Recorders
IPOD TOUCH WONT TURN ON
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
http://ccm.net/forum/affich-786664-5th-generation-ipod-won-t-turn-on
Apr 01, 2016 | Apple iPod touch
I got water in my creative zen and it won't turn on. Is there any way of fixing this?
Probably not.
Remove the battery and place the player in a warm sunny dry place for several days until it drys out completely. Replace the battery, charge it and the see if will work.
Aug 20, 2012 | Creative Technology ZEN Mozaic Pink (4 GB)...
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
I have a PDF ebook that I put in the Coby but it won't show up in my mp3 player!
In order to see and read pdf's on mp3 players it must support a pdf reader. I must be put in the correct folder and the the pdf version (of the ebook) can't be newer than the pdf reader else it won't read it. Coby doesn't like pdf format as one that is automatically read by the player.
May 24, 2011 | Coby MP620 MP3 Player
My mp3 from time to time would shut off or the screen would go black and won't shut off.
Same problem I had awhile back, make sure you don't have a memory card inside the player when you turn it on. It boots up in an incorrect order and doesn't start. To turn it off when it's stuck in that position I believe I held the sliding power button to "On" for 15 seconds.
May 10, 2011 | SanDisk Fuze MP3 Player
I can't seem to download videos into my mp3.
Good morning, afternoon, evening or night, whatever time you are viewing this. You are having trouble downloading videos onto your MP3 Player? Well there is a reason for and you probably won't like this... There is no way you can play videos on this MP3 Player. Sansa Clip doesn't support video files, only music files and audio podcasts. Sorry about this, but FixYa encourages you to come visit the website again soon. Again sorry, but I hope you have a good day, evening or night, whatever time you are viewing this solution post.
Apr 26, 2011 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa MP3 Player Logo
63 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
