Question about Konica Minolta DiALTA Di200 Copier
Makes dark line on paper
When paper makes copy dark lines appear on copied paper
  • 92 Answers
If you are using your doc feeder check and see if there is anything on the small glass the one that is about an inch wide other then that could b fusing or drum issue
Posted on Jun 26, 2009
Mx2300n when i copy using the fast top bit,i get a horizontal black line accross the paper
hi, you need to clean the scaning glass, if it is soiled ,dark lines appears on the copies/scanned documents
Mar 28, 2018 | Canon Office Equipment & Supplies
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
Problem with copy/scan from Feeder
clean that small glass on printer if problem still continue open all machine and try blow it blower machine!
Apr 25, 2012 | HP Officejet 4500 Wireless All-in-One...
A vertical black line appear on each paper when the document feeder is used to make copies; such vertical line does not appear on papers when copying on the glass surface. How do I resolve this...?
when you open the copier platen cover, left of the copy glass, there is small narrow glass, which is used when you make copies from ADF. Over that glass is plastic protective sheet. Remove it and clean, also clean the glass. Use glass detergent and after cleaning dry it!
Even the smallest dirt can cause lines!
Hope that helps!
Apr 25, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Dark line when trying to make original copies.
The type of printer you have reads the image you want to copy by passing the paper in front of a image reader (it is like a wand with a light-slit on a side).
If someone passed in front of this reader a paper with something like dirt on it (or typing corrector not dry enough) some of that could stick ON the light-slit, so that the section covered with it cannot read any more the image you want to copy at that point!
Try to make a copy and look from above or aside where that light-wand is located, then try to clean it with a clean hanky. It could involve some technikal skills, maybe you have to loose some screws to get to it.
If dirt stick on it after this, try with some alcohol (no solvent please!). After cleaning the reader, copies should come out ok, please let me know.
Rate the solution please! Thx
Jan 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Konica Minolta DiALTA Di200 Copier Logo
159 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
