Question about Bryant 462AJC021BA Air Conditioner
Air conditioned not running
My AC unit isnt running, i hear a clicking sound like my AC unit wants to start, can you give me some advice on whats wrong
    Sergeant:
  • 340 Answers
Compressor problem that clicking is a relay for the compressor check your breaker.
Posted on Jun 21, 2009
  • taa43 Jun 21, 2009
    call for service hand holding cost
  • taa43 Jul 01, 2009
    lol Tom
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
Air conditioner making clicking sound when it's turned on
Check the belts that around ac pump but start the car and put ac on open bonnet take a long screw driver hold it down on the pump make sure u got a clear gap and put ur hear to the other end of screw driver. And do that to water pump power steer pump u wil hear which one is noise.
Apr 08, 2012 | Air Conditioning and Heat for Nissan...
My ac central air is blowing air but not cold
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
Jun 22, 2011 | Goodman CKL36AR36 Air Conditioner
Carrier ac model 38ckc does not cool properly. Outside unit runs but air coming out of the top is cooler than the other units that we have. Just had a service replacing all the filters and coolant checked...
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new compressor
Jun 20, 2011 | Carrier 38CKC036 Air Conditioner
We have Goodman AC unit...not sure what kind. It has blown VERY cold until the last few days where it would stay a little above where I had it set. Then yesterday I realized it was incredibly hot. My...
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Heating & Cooling
I have a TRANE XR12 central AC UNIT, when i turn my thermostat on i get a click sound and ac unit does not come on. i checked the circuit breaker to make sure it's on.i have not turned this ac on for a...
There is a time delay on the stat to the AC unit, in addition the AC unit likely has one also, so immediate activation as desired isnt likely, however in 10 minutes of asking for AC if its not on still Id check the time delay fuses in the service disconnect at the AC unit, its a small grey box with the power cords running to and from it, there is 2 time delay fuses inside this box.
Jan 12, 2011 | Heating & Cooling
Air Conditioning of my Renault Megane is not
Hi
Have the driver's door window open and the front bonnet open,
we are going to listen for a clicking noise, the noise that we are listening for is the Compressor engagement being activated after three seconds from the control panel.
Start the engine and switch on the air conditioning by pressing the AC button (with a request for maximum cold temperature and the passenger compartment fan running).
If you hear that clicking noise, then it is most likely that you have a leak from the AC system or a possibly in need of a top up do to service of the system not been carried out.
Otherwise if you don't hear that clicking noise then there is a case that the Compressor clutch is not being engaged.
Do to the following reasons
1. fuse blown in the UPC in other terms the fuse box (engine compartment)
2. AC Compressor faulty
3. AC pressure switch faulty
4. If there is not the slightest bit of pressure left in the system which is very unlikely.
I hope this information was somewhat helpful for a real diagnosis test a diagnostic tool is needed.
Enjoy.
May 01, 2010 | 2005 Renault 181
I have a goodman CPE30-1AB and when i turn the thermostat on to ac i can hear the ac unit cut on outside but the air isnt even cold... even though i can hear it blowing out.... what could be the problem...
the compressor may not be running turn the unit off get it serviced
I do not know the service rates for the area where you are to find out what is wrong For me to show up in Minnesota 80.00 call reputable co. Tom
Jun 22, 2009 | Goodman CKL30AR30 Air Conditioner
Clicking sound
is it just the normal operation sound of the ac pump cutting in?
Jun 11, 2008 | 1997 Mercury Tracer
Bryant 462AJC021BA Air Conditioner Logo
226 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
