Question about Logitech DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2)
Steering control steering no longer holds straight
  • kaykay88 Mar 25, 2008
    Steering wheel is always slightly turning towards right... If i take my hands off the wheel then the vehicle moves towards the right..
INCREASE THE STEERING SENSITIVITY
Posted on Dec 26, 2007
I also had this problem i do not know how to increase the steering sensitivity...HOWEVER repacking the bearings and then replacing the front suspension and also the tire fixed the pull completely!!! but this is an expensive fix...
Posted on Jul 05, 2008
Key stuck in ignition
Firstly wiggle the steering wheel back and forth to ensure the steering lock is not holding it in there (you have likely done that anyway). Then get a pair of pliers or multigrips to take a firm hold on the key, and wiggle it slightly up and down while trying hard to extract it. Some force may be required so make sure to pull only straight along the axis of the key while bouncing it up and down a little.
In any case it seems the key and lock are worn down so they don't match any longer. Your best option in the long term is to buy a new lock cylinder and have an auto locksmith (some do specialise - they are the ones who do work for dealers) rejig it to match the best key you still have.
If you cannot get the key out that locksmith will be needed as the next step.
Oct 15, 2014 | GPS
Steering wheel audio controls dont work when steering wheel is straight
you wll have to remove the steering wheel to find the problem iam afraid ,its called a serpent coil or whatever and this is playing up ,make sure ignition is off nd remove the airbag to get to the steering controls but whatever you do remove the airbag but do not unplug it or the airbag light will stay on
Mar 28, 2012 | Cars & Trucks
How to install part sw5928 cruise control switch to a 1998 ford ranger
1 Open the hood and loosen the clamp bolt on the negative battery cable with an adjustable wrench turned in a counterclockwise direction. Pull the cable straight up and off of the terminal and push it aside. Wait 15 minutes, before continuing this procedure, to allow the air bag circuitry to deactivate.
2 Pry the two plastic screw covers from the rear of the steering wheel spokes in the passenger compartment with a flat blade screwdriver. Remove the two screws revealed after removing the covers with an 8 mm socket attached to a ¼-inch drive ratchet wrench turned in a counterclockwise direction.
3 Lift the horn pad straight up from the top of the steering wheel. Carefully pull the air bag wiring harness connector from the bottom of the horn pad. Set the horn pad aside.
4 Remove the two screws holding each cruise control switch (there are two switches, one on each side of the steering wheel) with a Torx screwdriver turned in a counterclockwise direction. Lift up on the switch and pull the wiring connector apart with your thumb and forefinger. Repeat this action for both switches. Remove the switches from the steering wheel.
5 Install the new switches (make sure the "On/Off" switch is on the right-hand side) onto the steering wheel using the original mounting holes. Tighten the holding screws with a Torx screwdriver turned in a clockwise direction.
6 Push the air bag wiring connector back into the bottom of the horn pad until it is fully seated. Place the horn pad into position on the steering wheel. Tighten the holding screws from the back of the steering wheel with an 8 mm socket and ratchet. Push the two screw covers into the back of the steering wheel until they snap into place.
7 Place the negative battery cable back onto the terminal and tighten the clamp nut in a clockwise direction with an adjustable wrench. Close the hood.
Jun 19, 2011 | Ford Ranger Cars & Trucks
Cannot steer in PS3 -
you could try recalibrating your steering will and it should work
Jul 04, 2010 | Logitech Cordless Precision Controller for...
Steering locks and won't turn
might be how close u r to the wii cus if ure further than 2.5 m it will recognise buttons being pressed but not motions
May 08, 2010 | Nintendo Mario Kart (Wii) for Wii
We have a Sears Craftsman riding mower 917.258671 the steering wheel has a lot of play in it and has turned a full half turn when going straight. In other words the top of the steering wheel is at the...
The steering assembly your mower has is very difficult to repair. Thank God they no longer make that type. Forget about trying to tighten that screw, it won't solve your problem anyway. Believe me, you should take it to a repair shop.
Oct 03, 2009 | Craftsman Garden
Too much play in steering wheel I tried tightening the worm gear but it didn.t work
sounds like your steering control-arm bushes.....jack the car up so the wheel is 1 inch off the ground, get someone to wiggle the steering wheel, while you check the arm bushes, , you will see straight away if there is play in the bushes.(.you can also grab hold of the steering arm and give it a shake ).......this are not an expensive, or complicated repair..........good lick, and if this helps, could you please leave me feed back...many thanx
Aug 23, 2009 | 1994 Ford Econoline
Replace airbag on `92 honda accord
When an SRS cable reel assembly is removed and set aside during vehicle repairs, the cable reel may rotate inside the assembly so it is no longer centered. If the assembly is reinstalled with the reel off-center, the cable can break when the steering wheel is turned to full lock. The cable reel holding fixture locks the reel while the assembly is off the vehicle, keeping it centered for reinstallation.
CABLE REEL REMOVAL PROCEDURE
1. Follow the procedure in the appropriate service manual for disconnecting the battery, and removing the dashboard panels, steering column covers, airbag, and steering wheel.
^ Always install short connectors on the connectors for the driver's and passenger's (if so equipped) airbags.
^ Make sure the front wheels are pointed straight ahead before removing the steering wheel.
2. Verify that the cable reel is centered; the yellow gear tooth is lined up with the alignment mark on the cover. Install the cable reel holding fixture in the cable reel assembly as shown. Use a TORX T-10 wrench.
3. Disconnect the 6-P connector, then remove the cable reel assembly.
CABLE REEL INSTALLATION PROCEDURE
1. Verify that the front wheels are still pointed straight ahead.
2. Reinstall the cable reel assembly, and reconnect the 6-P connector.
3. Remove the cable reel holding fixture.
4. Follow the service manual procedure for reinstallation of the steering wheel, airbag, steering column covers, and dashboard covers.
5. Verify SRS operation as described in the service manual. Road test the vehicle.
^ If the steering wheel spoke angle is not correct, change it by adjusting the tie rod ends. Do not remove and reposition the steering wheel.
PARTS INFORMATION
Cable reel holding fixture:
For 1992-95 Civic and Ohio-produced 1992-95 Accord
P/N 77900-SPO-999, H/C 4733564
For 1991 Accord Wagon, 1992-95
Prelude, 1995 Odyssey and Japan-produced
1992-95 Accord
P/N 77900-SM5-999, H/C 4733572
WARRANTY CLAIM INFORMATION
Use the Flat Rate Manual information for the repair being performed.
Jan 28, 2009 | 1992 Honda Accord
Logitech DRIVING FORCE FEEDBACK STEERING WHEEL W/PEDALS USB FOR PS2 (VGITECHWHEELPEDALSUSBPS2) Logo
246 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
