Question about Conair WW81 Weight Watchers Body Fat/Hydration Scale
How to change the battery of thinner scale R112003
My scaleneeds a new battery and I cannot find where the battery is located?
SOURCE: Problem changing battery for Conair Thinner Scale TH300
My scale is an older model, "can't locate model# in or outside" sticker on back plate is RH697. Scale was purposely setup so that no one can change the battery but a tech. Back plate had no instruct as to where battery is and the 4 small phillips screws were covered with rubber filler. I scraped off the rubber filler and opened it up, inside was a computer board which I took out (6 tiny phillip screws) to get to the battery (it was the expected 3V) the battery was front and back soldered in. That was enough for me, this company is nothing but a bandit forcing you to a tech (est. cost 45-60$) or to make another purchase. True piracy, I'm throwing it out. Make sure when buying anything that runs on batteries that the product offers ease of replacement, I am disgusted with Thinner.
Posted on Oct 10, 2010
  • 1082 Answers
SOURCE: I have a Thinner glass/brass
This is a coin size battery.
From the manual...
"Power Supply
This scale requires (1) 3V lithium battery.
The battery compartment is located on the back of the scale platform."
http://www.conair.com/instruction_booklets/08pl011%20th220r_ib.pdf
Scroll down this page to read customer reviews.. Seems like you'd have to take it apart to replace the battery.
http://www.amazon.com/Thinner-Scale-Conair-TH301-Silver/dp/B000OCP5V8
Posted on Jan 09, 2011
SOURCE: I have a Conair Thinner Scale which has worked for
I have the same problem. I would like to know if anyone found the solution.
Posted on Dec 06, 2011
r321567499
  • 74 Answers
SOURCE: battery cover
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
My batteries are new, the scale reads error and will not reset. I have taken batteries out and changed it from lbs to kgs and moved it and nothing works? Please advise.
I was surprised to learn that SOME digital scales are VERY particular about the batteries users install! (I-KNOW!)
LOOK CLOSELY to see what battery your scale specifies.
Please let us know how this works for you?
Anthony
Jan 29, 2018 | The Health & Beauty
My scale (thinner)MS 7400 stop working?
Most likely the batteries need to be replaced. If you put in new batteries and it still doesn't work, it may be time for a new scale.
Mar 02, 2015 | Health & Beauty
I have a Nixon Lodown and I can't seem to figure out how to save a new tide location. it lets me select a location and then it asks me for the date. After i enter the date it goes back to selecting the...
Has it had a new battery recently? Some of these watches need to be reset properly in order for them to work right, if it has had a new battery this could be your problem. It would need to be reset from inside the watch
Dec 01, 2013 | Nixon Lodown Tide watch
My clock quit picking up the atomic signal, even with new batteries installed.
Try temporarily locating it in a different location until it picks up a signal, usually around a window.
Mar 01, 2013 | SkyScan 86709 Atomic Wall Clock
Exact location of battery saver relay in 2000 taurus
The relay would have nothing to do with that problem ,You have a short somewhere, take it into a auto electric shop to be check out,
Nov 28, 2012 | 2000 Ford Taurus
How do I replace a y510 cmos battery
Locate your CMOS battery
Caution: When inside your computer make sure you're aware of ESD and all it's potential dangers.
cmos.jpgOpen the computer case and find the battery on the computermotherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in locating it.
Obtain battery information
Unfortunately, most manufacturers will not list the exact type and model of your CMOS battery; therefore, once you have located the battery, write down all information about the battery (Voltage, chemistry, wiring, and packaging). If possible, remove the battery and take it to the location you plan on purchasing a new battery from. The part number for this battery for most computers is CR2032.
Additional buying information can be found on our battery buying tips page.
Removing the battery
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Users with computers that do not have removable batteries only options to install a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Insert the new battery
Once you have purchased a new battery, remove the old battery (as instructed above) and replace it with the new battery.
Enter CMOS values
Once the battery is replaced turn on the computer and resetting the CMOS values to the defaults. After the values have all been entered make sure to save the settings before exiting. Many CMOS setups allow you to press a key (such as F10) to save values and exit all in one action.
If after following all the above steps you continue to experience the same error when your computer starts or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
Apr 19, 2012 | Lenovo IdeaPad Y510 Notebook
I have a Thinner glass/brass round bathroom scale and I cannot find the battery location. I purchased this about 10 years ago from Frontgate but they couldn't help me. Can you?
I have a 10 year old Thinner bathroom scales also. Apparently the manufacturer designed it to make battery replacement hard so you'd buy a new scales. To replace the battery, if your unit is similar to mine, turn it over, remove all the screws and separate the top and bottom. You'll see the glass window that shows the weight. It is held in place by four tabs that are slightly twisted. Straighten them, lift the glass assembly clear without straining the wires, and turn it over to reveal the round black battery case. It is secured by three small screws and clear epoxy. Remove the epoxy with a knife blade, remove the screws, and separate the two halves of the case on one side being careful not to separate the other side where there is a metal connection piece. Using the knife tip, remove the CR2032 battery and replace it with a new one (available at Radio Shack or similar stores). Reassemble in reverse order; no need to replace epoxy. My scales worked fine after that.
Jan 09, 2011 | Conair WW81 Weight Watchers Body...
How do I know if the battery needs to be replaced?
mcdevito75 here, Generally if the unit slows down or just isn"t as efficient as it was, then it could be time to change the battery.
Jun 22, 2010 | Conair TH402 Thinner Digital Body Fat &...
Conair WW81 Weight Watchers Body Fat/Hydration Scale Logo
2,915 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
