Kyocera FS-C5030N Led Printer Logo
A
Anonymous Posted on Apr 28, 2014
Match envelope switches - Kyocera FS-C5030N Led Printer
1 Related Answer
Anonymous
  • 200 Answers
  • Posted on Feb 24, 2011
SOURCE: Describe your KYOCERA FS2020D Match envelope
Load the status moitor utility and using that you can set the bypass paper size to match the envolpe size you are using.
My printer it showing me match the position of envelope switches
Too vague a question. No 'make model (what it is)'.
Google
make model manual
They are all online. You can use CTRL+F to search for words or phrases in the manual if 'match the position of envelope switches', is in fact an error message and not just text within your question?
Help, fix the error code of Kiyocera Photocopy Machine "match the position of envelope switches"
Previous FIXYA question had two suggested answers:
http://www.fixya.com/support/t6209979-match_envelope_switches_error_message
match envelope switches error message cannot remove it cannot bypass it...
Quoting:
Open the back side of the printer. There are 2 buttons for the envelope. Switch them so that they are at the same position for normal paper. See also manual. It's described there. Posted on Sep 29, 2010
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts Posted on Sep 29, 2010
1helpful
How to fix match envelope switches?
On the FS-4000, this message can be cleared by releasing and pulling out the rear unit until it stops and making sure that the green pressure buttons on both ends of the fuser unit match. Both buttons depressed indicate envelope mode. Both released, indicate normal paper mode.
Duplex printing FS-2100D
in back of machine there is a fuser unit there are 1 or maybe 2 small green buttons or switches on it that is the envelope setting push the button or switch to put it back in normal paper mode
1helpful
2answers
The problem occur in my kyocera FS2020D switch envelop matches appear how can i handle it?
the problem occur in my kyocera FS2020D switch envelop matches appear how can i handle it?
Describe your KYOCERA FS2020D Match envelope Problem the printer is stating MATCH ENVELOPE SWITCHES?
8helpful
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Envelopes trigger ''wrong paper size'' every time in hp 1510
Have you made sure to choose the correct (matching) envelope size in your software?
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
