Dremel 300-N/55  300 Series Tool Kit
Problem for Dremel 300-N/55 300 Series Tool Kit
How do you change out sanding drum (on mandrel)
By mberry92 on Jun 21, 2009
How do you change out sanding drum (on mandrel) when sanding drum is worn down?
Best Solution
posted on Jun 21, 2009
Helpful)
pdbaker6
Rank: Guru
Rating: 90%, 46 votes
loosen the screw on the top of the mandrel. pull drum off rubber insert. the mandrel works by expanding and creating pressure on the sanding drum when screw is tightened. it does take a little pressure
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dremel 300-N/55 300 Series
Questions and Unsolved Problems for Dremel 300-N/55 300 Series
Do you recommend Dremel 300-N/55 300 Series Tool Kit?
Answer
Answer
Need to see the operators manual to adjust laser light on Rigid 10'' chop saw
Answer
My dremel 300 was working earlier today and now it doesn't, the outlet is fine and works with other... (More)
Answer
How do I attach the right angle tool. It looks really confusing and no instructions in the manual.
Answer
dremel tool # 572.610530, variable speed (1 to 5) purchased in 1998. The tool could be made to... (More)
Answer
I have a Dremel 300 and the shaft lock assembly isn't working to hold the shaft so I can get the... (More)
Describe your Rotary Tools problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Rotary Tool Experts
Top Garden & Power Tool Repairmen
in , AK
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
