Question about Canon CLC 1150 Color Copier
I own a Canon Laser Color Copier Model No. 1150 CLC1150. The error code when I start up the copier is E0000 0132. How can I fix this issue?
  • radert Jun 23, 2009
    Hi Ronnie59,
    Thank you for responding. I got into the Copier>>function>>Clear>Err>>OK, but when I click OK it doesn't do anything....it says error, and it appears that the word "SERIVCE" flashes real quick and then goes back to ERROR.
    A new problem now is the printer will only stay on for roughly 3 minutes and then it shuts down.....
    Is there something else I could try?
    Thank you!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
E0000-0132
the cause of error is the fixing heater/s is not functioning well .Try this press asterisk with the head then 2 and 8 simultaneously then same asterisk with head. The lcd display will change Pres the ff: COPIER>Function>Clear>Err > ok .to reset fixing error .Switch power off and on the machine.If the Error
return, you have to call the canon service agent to check your fixing/fusing unit and its components
regards
Posted on Jun 23, 2009
Error
CLC1150 problem code E020 0181
what is this? The machine has been off/on and we also this problem
info@setobemmel.nl
Jan 31, 2010 | Canon CLC 1150 Color Copier
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
E0000 0132 error on Canon CLC 1150
this is the fixing error indication reset it * 2 & 8 simultaneously * Copier>Function> Clear>Err>OK .Restart the Machine
Jun 20, 2009 | Canon CLC 1150 Color Copier
Clc1150 cannot connect to fiery
Your Fiery need"s system software reloaded. let me know if you need help to do so.
May 11, 2009 | Canon CLC 1150 Color Copier
How can i get the CANON CLC1150 to boot up on service mode?
toner cartridge mixute problem
go on line type conan printer error e020 interkey
look threw the problems and see what you wannt to fix the problem best solves the problem
Feb 02, 2009 | Canon CLC 1150 Color Copier
Canon clc 1150
9 times out of ten that means you need a new drum when it does print does it look ok?? if yes then its definatly the drum it measures the voltage on the drum when its worn this code happens sorry
Jan 16, 2009 | Canon CLC 1150 Color Copier
ERROR CODE
there is a problem with the fuser, replace thermistor or thermofuse
Aug 29, 2008 | Canon CLC 1150 Color Copier
Clc1150
you more than likely need the oil blade replaced. others things can be that you have paper jammed up at the top of the fuser which means youll need to open up the fuser.
May 07, 2008 | Canon CLC 1150 Color Copier
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
Canon CLC 1150 Color Copier Logo
182 people viewed this question
old marine
old marine
