Question about Maytag Atlantis MAV6451 Top Load Washer
Agitator spins slowly and wont drain water-slight burning smell when operating
    President:
  • 1,136 Answers
Hi, Th smell is most likely the belt. If the washer is not draining, the pump could be locked up and this will cause the belt to smell.
The pump is located underneath rear right corner. If you set the drain hose itno abucket and get the water out. you can tip the washer back and see if the pump is froze. I see you posted this premium but I didn't get to it in time cause I was asnwering this.
Hope it helps
Vic
Posted on Jun 21, 2009
Water wont drain from tub error code nd
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 07, 2012 | Washing Machines
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
I have a frigidaire washer model fws777ghs0.after the spin cycle the water is drained but the clothes are too wet.there is a smell of burning rubber.when I open the lid I could see a slight smoke.could it...
probably burned up your motor coupling! see if you can hear the motor running either on the agitate or spin cycle,if you hear the motor running but no movement then it's gonna be the motor coupling it's plastic and rubber! cost about $20
Jan 11, 2010 | Washing Machines
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
