My panasonic sd 512mb high speed camra card i use to put photos on my acer lap top is now not working.when i put it in my laptop the photos use to come up stright away,now when i put it in nothing comes up?it still works in my camra but nolonger works when put into my lap top?
Where do i put the memory card from my phone in my lap top
Your laptop must have a card slot, for it to be able to read the card.
First most phones use a micro sd card, so you need the card holder,
a card holder id a regular size sd card that you put the micro card into
and then you put this into a sd card reader if the laptop has one.
Most laptops,computers, can not read a micro sd card, only sd card,
and some mmc memory sticks.
You did not post who made your laptop, or the model number so we have no clue if your laptop has a card reader.
Feb 11, 2010 | SanDisk 4GB microSDHC Memory Card
Computer not finding SD card, I put the SD card in like normal but nothing happens. I go into computer and it does not show up there either
SD cards are not created equally! There is so much more to know than just the capacity.
There are many things about SD cards most people are not aware of. After having numerous problems with my cards, I thought I would share what I learned, mostly from online articles, trial and error!
There are SD cards (Secure Digital)
SDHC cards (SD high capacity)
and SDXC cards (SD extra high capacity, high performance)
Speed Class: There may be a C with a number inside the C printed on the card, (or a U with a 1 in it) - if there is no C or U on your card, it is a C2 card.
C2 is for basic data and photo use and has a slower processing speed.
C4 and C6 are acceptable for up to basic video.
C8 and C10 are high performance, fast processing speeds - and cost more.
The U1 symbol indicates fastest processing speed available, and will cost the most. For large size, HD videos.
If you are trying to use a basic SD2 card (no C rating or C2 rated) for a high quality or high speed video or large RAW photo, you may have problems with your device. The card may not be able to keep up speed-wise. These are generally older, or lowest priced cards. More information and photo examples on the speed class here: https://www.sdcard.org/consumers/speed/speed_class/
Your device will read SD cards up to the capacity it is capable of. A device with SDHC capability will be able to read basic SD cards, but might not be able to read an SDXC card, so you may think you have a defective card when you actually just have a device that does not have the capability to read it.
If your computer's SD reader or peripheral card reading device has an SD card reader and it cannot read SDHC (high capacity) or SDXC (extra high performance/capacity) it will reject or not see the card and you might think you have a defective card. Put the card in your camera or other device you are going to use it for, and then using the USB cord that came with the device, plug that into your PC. The PC will be able to read the card that way, edit it, etc.
After copying all files on the SD card to your computer, you may wish to format the card before using it again. When formatting the card, IMPORTANT: Make sure you have copied all the data you want to keep onto your hard drive, and make sure it is formatted FAT32. I kept formatting a card FAT (which was the default for this card), and the recordable capacity of the card kept getting smaller...and smaller...a 2GB card was only allowing 350, 250, 125 MB of data to be stored on it! I kept hitting a brick wall trying to copy files onto it. I kept formatting the card, thinking there was some de-frag issue or corrupted portion, and the capacity of what it would store kept diminishing - until I formatted the card FAT32. ONLY THEN was the card able to store to its true capacity. I was able to do this in Windows in Explorer - right click the drive the SD card is in, select Format, verify the Capacity (card size), verify the File System (use the pulldown menu to select FAT32 if it is not selected), and then click Start and allow the computer to remain undisturbed until the format is complete. I found a web page that covers this: http://pvillecomp.com/
There is an SD website that offers a download for proper formatting of your SD card, with downloadable instructions. I was using Windows to format my SD cards, but the SD website recommends using software that specifically formats SD cards. Here is the site: www.SDcard.org. Click the Downloads section.
Some older devices can only handle smaller SD cards (2 GB or smaller), so if your device cannot read a particular SD card...check your owner's manual. There is usually a limit to the size, capacity, speed, type, etc. of the cards each device can handle.
It is also possible to partition an SD card so it can be read by more devices, or separated for organization purposes. I prefer smaller SD cards when possible to avoid a huge loss if the card becomes damaged, lost, etc., but for those who have cards that are 16+ GB in size they may want to partition them. Here is a website for that:
http://forum.xda-developers.com/showthread.php?t=267475
Hope this helps!
Feb 07, 2010 | Acer Aspire 6930-6455 Notebook PC
SD Cards that show Not Formatted when put into a computer . . .
Try an SD card reader, theyre only a few bucks and they practically eliminate the need for the photo software that came with your camera. I use a card reader/writer which cost about $12 at WalMart
Sep 23, 2009 | Dell Latitude D630 Intel Core 2 Duo T7250...
Panasonic sd use to work in my acer lap top but now it dosent?
Try to find another PC and run your SD card, if it works fine, it means that your slot in ACER might need more attention to fix, try to clean it or try another SD card. If it still doesn't work, Try to run the RECOVERY TOOLS software that you might download it for free at www.c-netdownload.com GoodLuck!
Jun 21, 2009 | Computers & Internet
Micro sd hc 4gb wont work.
THe HC chip set for SD's and micro SD's have different programming in them and are unfortunately not backwards compatable with a standard SD host port. For you laptop, I reccoment getting a USB SD chip adapter. They're only like $6-$10 depending upon the brand. For your phone, however, I reccomend you take it back to the store for a trade-in on a standard SD chip, or for a complete refund so you can buy one from a store that carries standards.
May 01, 2009 | SanDisk 4GB microSD High Capacity Memory...
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
Does the micro sd card been detected by your computer? If not, you may try other card reader, or other computer. If still does not detected, you may try to go to device manager and see whether the sd card is there, if yes, then you can assign a drive letter to the sd card.
Once SD card shows as a drive letter on PC, you can download sd card recovery software to get back your files. recommended asoftech photo recovery that helped me before. download it from link below
SD Card Recovery Software
You can refer to this card recovery tutorial
Recover files from SD Card
If above does not work, you may have to format the memory card (use quick format), and then use Asoftech Data Recovery to scan again the memory card and recover your files.
Dec 09, 2008 | SanDisk 4GB microSD High Capacity Memory...
Sd card
have you try to insert it to another computer?
Feb 14, 2008 | HP DG937A - HP Tablet PC TC1100 Tethered...
Panasonic SD card
> The Panasonic 256MB SD card is twice as fast as the cheap SanDisk > 256MB I bought from Costco for $65. Saving the 5-shot burst at > 4MP, the Panasonic card takes only 2-3 seconds to save, whereas the > SanDisk card takes 5-6 seconds. Although the SanDisk works just > fine in video mode - I was able to fill the card with video. The > extra speed is also very noticeable on the Panasonic SD through my > 8-in-1 SanDisk USB2 reader on WinXP copying the files to my hard > disk. > > Has anyone tried SanDisk's "ultra" or other performance versions? > Any reason why the Panasonic is so much faster? the panasonic SD is rated at 10Mb/sec. ditto for the Sandisk Ultra II. I've got both versions of the Sandisk. the regular Sandisk is only rated at 2 Mb/sec which explains the slow save speed. the Sandisk Ultra II is much faster compared to the regular Sandisk.
Sep 04, 2005 | Panasonic SV-AS10 Digital Camera
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
