RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Problem for RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Why does my 52 rca tv keep turning itself off and making a hiss?
By mabu0106 on Jun 21, 2009
it turns off
Best Solution
posted on Jun 22, 2009
Very Helpful)
fillmore85
Rank: Wiz
Rating: 88%, 18 votes
Unplug the tv, take off the back cover and feel the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jun 21, 2009
Not Rated)
willtab
Rank: Guru  RCA Expert
Rating: 90%, 772 votes
the rca itc222 chasis is a rather problem child that has many common problems. the most common being the flyback transformer, the horixonatal output transistor, and some electrolytic capacitors. technicians have a device much like the computer for cars that read error codes of the processor. i believe ther around 25 different errors that can lead to a shutdown
Was this helpful?
Yes
No
Popular Solutions for RCA D52W20 52 in. Rear
Questions and Unsolved Problems for RCA D52W20 52 in. Rear
Do you recommend RCA D52W20 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
i have a rca d52w20b it worked untill it was pushed up 2 the wall and broke the coax input off. now... (More)
Answer
when I turn on the tv after few minute the picture turn horizontal
Answer
I have an RCA HDTV Monitor TV. The picture looks 3D and there are three gentle U shaped lines at the... (More)
Answer
when I push ''on'' button or use remote, the light on power button goes on and off three times and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
