Question about Kenwood DDX-512 Car DVD Player
1995 740il BMW (e38) Lights flicker and batt dies.
Parked my e38. In the morning i noticed the headlights flickering back and froth. when i tried to start the car it needed a jump. after jumping the tach and speed did not work. thinking it was the alternator i charged the batt and load tested it . looked good. parked the car and 24hours later the lights started to go on by themselves thus making the battery die again. alternator is orig for car and the batt is a few years old.
3 Suggested Answers
  • 37 Answers
SOURCE: I have an issue.. my
Hello Melissa,
The first thing I would check is if your fuse is okay. If your fuse is blown replace and try to turn on the radio. If the fuse is good have the radio taken out and have it bench tested. take the power wire and the memory wire put them together and apply power to them then take the black wire and connect it to ground if the radio turns on then its okay and he fried something else. If the radio doesn't turn on then chances are that he fried it.
You can use a car battery to test your radio or a portable boost jumper.
Hope this helps you.
Posted on Dec 04, 2008
  • 11 Answers
SOURCE: Turned the car on and no power, only a flashing red light.
YOUR KILLING YOUR ALTERNATER
that would cost more than a grand to replace.
I advise that you get ur battery tested by AAA or any local maintenece shop.
Posted on Sep 11, 2009
Engine wont start and there's a light flickering every 2 seconds on dashboard
mazda not to jump start need to remove battery and charge
try this and see Howard ase master
Sep 10, 2013 | Mazda MAZDA3 Cars & Trucks
Monte carlo 2003 flicker and gauges move up and down with nos out of skeakersrs.
Sounds to me like you have a loose connection. Check to make sure you can't twist the cable on the post and the the bolt/nut is tight for both + and - terminal. If they are tight, is there a lot of corrosion on the cables and or battery post? Take a wire brush or battery cleaner tool and get the contracts cleaned up and retighten. I'd bet that should solve you problem if you can start it with a jump.
Oct 20, 2017 | Computers & Internet
2003 BMW 325I won't start
How did you test the battery? The fact that you jumped it and drove home with no problem tells you the battery is the problem.
Jan 01, 2018 | BMW 325 Cars & Trucks
I have a 1997 Chevy Malibu (140K miles). The car was well maintained by prior owner. I have experienced the antitheft problem where I get locked out and have to wait 10-15 minutes. That has occurred...
i to have had some FUN with this darn system and replaced ignition cylnder(dealer has to program)can help usally for a few years ....but i dont want to swaer thats the samething causeing yours......feel free to repost
Dec 21, 2010 | 1997 Chevrolet Malibu
My 99 vw jetta will not turn over
Check your battery cables for tightness, especially your ground cable. Now you have a new battery, so you have eliminated that as the source of the problem. Turn on your headlights, do they go out or very dim when attempting to start the car? If so, you have a poor electrical connection somewhere - loose cable, bad cable, possibly bad ignition switch.
Dec 24, 2008 | 1999 Volkswagen Jetta
2003 VW Golf won't start - battery was charged
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Dec 04, 2008 | 2003 Volkswagen Golf
1996 Subaru Legacy No Power At All
Last night I checked the battery and it was still good. I disconnected and then reconn ected both terminals and that brought the power back. When I turned the key the power went out again. I repeated the procedure but did not turn the key. Instead, I took off the knee bolster and tried to wiggle the wires under the dash to see if I could find the source since it seems to be related to the ignition. Nothing cut the power so I started it up and it worked fine except for the check engine light which was flashing that says I have a misfire condition. I drove the car 25 miles to work this morning and will be taking it to the dealer for a better inspection.
Aug 21, 2008 | 1996 Subaru Legacy
Kenwood DDX-512 Car DVD Player Logo
194 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
