Question about GE Profile PSS26NGS Side by Side Refrigerator
Ge ref will not go above 22 deg. - GE Profile PSS26NGS Side by Side Refrigerator
3 Suggested Answers
SOURCE:
SOURCE: GE Profile
DONT KNOW?
Posted on Jul 22, 2008
  • 159 Answers
SOURCE: GE refrigerator works intermitently
change the thermostat my dads fridge did the same
Posted on Aug 13, 2009
Unit will not heat, change batteries controller cleaned filters etc. Still blowing COLD air
Check the thermostat setting...in the auto machines, with a reversing valve, there is no heating or cooling, generally, in the sensing temperature band of 19 Deg C to 22 Deg C and it only works on blower mode, re-circulating the room air. When the sensing temperature goes below 17 deg C, it works on heating and when the sensing temperature goes above 24 deg C, it works on cooling
Sep 05, 2011 | Heating & Cooling
Freezer freezes too 22 deg below 0 & fresh side to only 65 deg, above cuuld this be a thermostat prob?
fAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 24, 2011 | Whirlpool Refrigerators
I have GE ref, its been a 6 years old. when the temp.reach to 5 deg. it stops the compressor. but the thermostat setpoint is very low. what seems to be problem
Thermostats are common to fail or get out of range, have you had it colder in the past? Is the thermometer that your checking it with accurate.Or are you just wanting it colder now. 5 degrees is not that bad except for ice cream ect. Although its not a problem for you at this time, is the condenser coil clean?
Jul 03, 2011 | Refrigerators
My SXS-22 makes ice but will not kick the ice out into the ice bin.
mold heater in ice mker has failed . and ice will not release . . best to repl the ice mker . / do ck freezer tempt . as it should be 15 deg or lower . .. mm
Sep 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Aug 11, 2009 | GE Refrigerators
Freezer temp 7-20, ref temp steady 35. Ice on return line
HI thanks for your question. the way that frost builds up on the return line is the freezer is running too long . you have the temp set at too cold a setting 34 deg is too cold. it should be 36. 37. other wise frost builds up.thanks the appliance doc. please rate my answer. thanks.
Aug 13, 2008 | GE Monogram ZICS360NRRH C... Bottom...
GE Profile PSS26NGS Side by Side Refrigerator Logo
15 people viewed this question
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
